4 Replies Latest reply on Oct 31, 2014 1:38 PM by creativejoan0425
    About Dropdown list on change
    creativejoan0425 Level 1
      I have a Dialog, when I choose choice 2 the second dropdown with change to the list "1", "2","3","4","5","6","7","8","9","10","11", and choose choice 1 the list should be "A","B","C","D","E","F","I","J", but now when I choose choice 1 or 2, the list will not change
      var myObject;
      var mySelArray = null;
      var myDialog = new Window("dialog", "Test_v1.0");
      myDialog.alignChildren = ["fill","fill"];
      var g1 =myDialog.add ("group");
            g1.alignChildren = "top";
      var myPanel = g1.add ("panel");
            myPanel.orientation = "column";
            myPanel.alignChildren = "right";
      var myLangGroup = myPanel.add ("group");
      var group1 = myLangGroup.add ("group");
            group1.add ("statictext", [0, 0, 60, 20], "Language:");
      var group2 = myLangGroup.add ("group");
      var myDropdown1 = group2.add("dropdownlist",undefined, ["Choice 1", "Choice 2"]);
            myDropdown1.itemSize = [200,20];
            myDropdown1.active = true;
            myDropdown1.selection = 0;
      var myGlobalListGroup = myPanel.add ("group");
            myGlobalListGroup.alignChildren = ["fill","fill"];
             myGlobalListGroup.alignChildren = "left";
      var group5 = myGlobalListGroup.add ("group");
            group5.add ("statictext", undefined, "Change To:");
      var group6 = myGlobalListGroup.add ("group");
            group6.orientation = "column";
            group6.alignChildren = "right";
           var myArray1 = ["A","B","C","D","E","F","I","J"];
           var myArray2 = ["1", "2","3","4","5","6","7","8","9","10","11"];
      //~                 }//end of loop
      if(myDropdown1.selection == 0){
              mySelArray = myArray2;
      else if(myDropdown1.selection == 1){
              mySelArray = myArray1;
      var myDropdown2 = group6.add("dropdownlist",undefined, mySelArray);
            myDropdown2.itemSize = [200,20];
            myDropdown2.active = true;
      var mySearchRangeGroup = myPanel.add ("group");
            mySearchRangeGroup.alignChildren = ["fill","fill"];
            mySearchRangeGroup.alignChildren = "left";
      var group7 = mySearchRangeGroup.add ("group");
             group7.add ("statictext", undefined, "Search Range:");
      var group8 = mySearchRangeGroup.add ("group");
            group8.orientation = "column";
            group8.alignChildren = "right";
      var myDropdown3 = group8.add("dropdownlist",undefined, ["i", "ii", "iii"]);
            myDropdown3.itemSize = [200,20];
            myDropdown3.active = true;
      var myRangeGroup = myDialog.add ("group");
            myRangeGroup.alignChildren = ["fill","fill"];
           myRangeGroup.alignChildren = "left";
      var group9 = myRangeGroup.add ("group");
            group9.orientation = "column";
            group9.alignChildren = "left";
      var myRange1 = group9.add("radiobutton", undefined, "with Markup");;
      var myRange2 = group9.add("radiobutton", undefined, "without Markup");;
          myRange1.value = true;
          myRange1.active = true;
      var myBottomGroup =  g1.add ("group");
           myBottomGroup.alignChildren = ["fill","fill"];
            myBottomGroup.orientation = "column";
            myBottomGroup.add ("button", undefined, "OK");
            myBottomGroup.add ("button", undefined, "Cancel");
      //----------------------------------------end of Dialog------------------------------------------------------
      //-----------------------------------------onChange ---------------------------------------------------------
      myDropdown1.onChange = function() {
      switch (myDropdown1.selection.index) {
          case 0 :
          mySelArray =myArray2;
          return mySelArray;
          break;
          case 1 :
          mySelArray= myArray1;
          return mySelArray;
      var myWindow = myDialog.show();
      if (myWindow == true){
        • 1. Re: About Dropdown list on change
          cchimi Level 2
          You're not actually repopulating the list. I use a little function to populate a box that takes items. Here's a simplified version:
              function fillLBox(funcLBox, funcArray){
                  if (!(funcArray instanceof Array)) {}
                  else{
                      for (var i = 0; i < funcArray.length; i++){
                          var myListing = funcArray[i];
                          if(myListing instanceof String){
                              funcLBox.add("item", myListing);
                          else{}
          then, in your onChange function, do something like this:
          myDropdown2.removeAll();
              case 0 :
              fillLBox(myDropdown2, myArray2);
              break;
              case 1 :
              fillLBox(myDropdown2, myArray1);
          • 2. Re: About Dropdown list on change
            I try your script, but when I choose Choice 2 , it will have a dropdownlist but it is blank
            • 3. Re: Re: About Dropdown list on change
              cchimi Level 2
              Sorry, I forgot to update one line. Change
              to
              if(typeof myListing == "string"){
              I really wish I could edit my posts to make this clearer, but that should do it.
              • 4. Re: Re: About Dropdown list on change
                Cool, it work, thx
