1. Re: Premiere Pro will not export to BluRay.
shooternz Oct 31, 2014 12:50 PM (in response to SmilingTigerVideo)You need Encore to burn a DVD.
You need CS6 and Encore if you want to directly burn it from Premiere.
If you want to use CC versions of Premiere...you need to export a file that you can use in Encore ( or similar) to burn a DVD.
2. Re: Premiere Pro will not export to BluRay.
SmilingTigerVideo Oct 31, 2014 1:02 PM (in response to shooternz)Then why does sales tell Premiere Pro CC can do it without CS6 support?
3. Re: Premiere Pro will not export to BluRay.
shooternz Oct 31, 2014 1:11 PM (in response to SmilingTigerVideo)You can do it without Premiere CS6 but you need to export a file and work directly in Encore (or similar) to burn the DVD
Get the trial version and find out.
AFAIK - There is no Direct route to Encore from Premiere CC
4. Re: Premiere Pro will not export to BluRay.
John T Smith Oct 31, 2014 1:36 PM (in response to SmilingTigerVideo)CS5-thru-CC PPro/Encore tutorial list http://forums.adobe.com/thread/1448923 will help
The bottom section of the link above has several Adobe links, and other information, on downloading Premiere Pro CS6 and the bundled Encore CS6, and the TWO ADDED downloads for the Encore library content, to author a DVD or BluRay... and the tutorial list includes learning how to use Encore... pay particular attention to the picture in reply 3 at this link - https://forums.adobe.com/thread/1516173 (picture first posted by Ann Bens and reposted by Stan Jones)
5. Re: Premiere Pro will not export to BluRay.
SmilingTigerVideo Oct 31, 2014 1:48 PM (in response to SmilingTigerVideo)Thanks for the help. I'm in process of downloading CS6 for Encore. Hopefully, the Force will be with me for the rest of the day, because until now I was about to join the dark side.
6. Re: Premiere Pro will not export to BluRay.
Stan Jones Oct 31, 2014 3:22 PM (in response to SmilingTigerVideo)Just FYI, there is no Encore trial.
