1 Reply Latest reply on Jul 2, 2015 10:36 PM by MACnTUTOR
    Why not appear in my Fireworks Create Slideshow, what happen? I hope a urgent answer.
    oscariglesias
      In the Create Slideshow comands menu does not appear and says he has to show up, what happens? Why am I not listed?.
      En Español: TITULO ¿Por qué no me aparece en mi Fireworks, Create Slideshow? ¿Qué sucede? Espero una respuesta urgente.
      En menu Comandos no aparece y se dice que debería aparecer, ¿Qué sucede? ¿Por qué no me aparece?.
        • 1. Re: Why not appear in my Fireworks Create Slideshow, what happen? I hope a urgent answer.
          MACnTUTOR Level 3
          That command was removed in CS6.
          In the What's new in Fireworks CS6 doc (http://helpx.adobe.com/content/help/en/fireworks/using/whats-new-cs6.html), note that Create Slide Show was one of five deprecated features.
          Use multiple files as one animation
          Fireworks can create an animation based on a group of image files. For example, you can create a slide show based on several existing graphics.
          1. Select File... Open.
          2. Shift-click to select multiple files.
          3. Select Open as Animation and click OK.Fireworks opens the files in a new single document, placing each file in a separate state in the order in which you selected it.
          Use the States panel to edit your animation. Be sure to choose "Animated GIF" in the Optimize panel.
          Cycle2
          Here is an easy option that requires no scripting: Cycle2 is a versatile slideshow plugin for jQuery built around ease-of-use. It supports a declarative initialization style that allows full customization without any scripting. Simply include the plugin, declare your markup, and Cycle2 does the rest.
          Cycle2
