2 Replies Latest reply on Nov 1, 2014 9:00 PM by bstrx
    Is it possible to check if action from some action set exists?
    bstrx
      In photoshop script (CC 2014) I'm executing doAction with action and action set that can possibly be not added yet. I wonder if i can somehow check if action exist first.
      all code i have:
      document = app.open(new File(inputFile));
      // some check if there is such action ?
      app.doAction(actionToRun, actionSetToRun)
        • 1. Re: Is it possible to check if action from some action set exists?
          xbytor2 Level 4
          The simplest way is to run the action. If it throws an exception, check to see if it's the exception for a missing action.
          try {
              app.doAction(actionToRun, actionSetToRun);
          } catch (e) {
             // Check e to see if it's the missing action exception.
          Or you can use this function extracted from xtools/xlib/stdlib.js.
          function hasAction(atn, atnSet) {
            function cTID(s) { return app.charIDToTypeID(s); };
            var asetDesc;
            var rc = false;
            var i = 1;
            var asMatches = [];
            while (true) {
              var ref = new ActionReference();
              ref.putIndex(cTID("ASet"), i);
              var desc;
              try {
                desc = executeActionGet(ref);
              } catch (e) {
                break;    // all done
              if (desc.hasKey(cTID("Nm  ")) &&
                  desc.getString(cTID("Nm  ")) == atnSet) {
                asetDesc = desc;
                asMatches.push({ index: i, desc: desc});
                //break;
              i++;
            if (asMatches.length == 0) {
              return false;
            for (var i = 0; i < asMatches.length; i++) {
              var asmatch = asMatches[i];
              var asetIndex = asmatch.index;
              asetDesc = asmatch.desc;
              if (!asetDesc.hasKey(cTID("NmbC"))) {
                continue;
              var max = asetDesc.getInteger(cTID("NmbC"));
              for (var j = 1; j <= max; j++) {
                ref.putIndex(cTID("Actn"), j);           // Action index
                ref.putIndex(cTID("ASet"), asetIndex);   // ActionSet index
                var desc;
                try {
                } catch (e) {
                  break;   // all done
                    desc.getString(cTID("Nm  ")) == atn) {
                  return true;
            return rc;
          • 2. Re: Is it possible to check if action from some action set exists?
            bstrx Level 1
            Thank you for such detailed answer!
