5 Replies Latest reply on Nov 2, 2014 6:23 PM by A.T. Romano
    Lines & Ghosting
    crashovaride
      I'm attempting to put together a video of my daughter.  All the clips included in the video were shot on an iPhone 6 and loaded into Premiere Elements 13.  Some, but not all of these clips show lines and ghosting as shown in the image below when placed in the timeline, these lines and ghosting are also present in the exported files.  The lines and ghosting are not present in the original clips outside of Premiere Elements.  Any idea what i'm doing wrong?
      Thanks in advance
        • 1. Re: Lines & Ghosting
          A.T. Romano Level 7
          crashovaride
          What computer operating system is your Premiere Elements 13 running on? For now, I will assume Windows 7, 8, or 8.1 64 bit.
          Please put your iPhone 6 video through the MediaInfo (Tree View)
          MediaInfo | SourceForge.net
          and let us know the properties of your cell phone video.
          Cell phone video can be a problem for Premiere Elements (several versions)
          a. out of sync audio
          b. failure to import
          c. other
          due to the cell phone video being recorded with a variable rather than constant frame rate. If we see 3 frame rates listed
          for your cell phone video in Media Info (min. in between max), then we will know that we are dealing with video recorded with
          a variable frame rate. We can try to convert the variable to constant frame rate with a free program such as HandBrake.
          We also have to establish that you (manually) or the program (automatically) are setting the correct project preset to match
          the properties of your cell phone video. After you import your video into the Premiere Elements project, tell us what you see
          under Edit Menu/Project Settings/General for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio.
          Let us start here and then decide what next.
          Thank you.
          ATR
          • 2. Re: Lines & Ghosting
            crashovaride Level 1
            Thanks for the quick reply.
            Operating system is Windows 7 64 bit. Premiere Elements has been automatically setting the project settings.
            PROJECT SETTINGS
            Editing Mode: HD 1080i
            Timebase: 29.97
            Frame Size: 1920x1080
            Pixel Aspect: Square Pixels (1.0)
            MEDIAINFO
            General
            Format                                   : MPEG-4
            Format profile                           : QuickTime
            Codec ID                                 : qt
            File size                                : 11.9 MiB
            Duration                                 : 5s 698ms
            Overall bit rate                         : 17.4 Mbps
            Recorded date                            : 2014-10-30T16:37:07+0800
            Encoded date                             : UTC 2014-10-30 08:37:08
            Tagged date                              : UTC 2014-10-30 08:37:14
            Writing application                      : 8.0.2
            Writing library                          : Apple QuickTime
            ©xyz                                     : -31.7946+115.9897+032.178/
            Model                                    : iPhone 6
            Make                                     : Apple
            com.apple.quicktime.model                : iPhone 6
            com.apple.quicktime.software             : 8.0.2
            com.apple.quicktime.make                 : Apple
            Video
            Format                                   : AVC
            Format/Info                              : Advanced Video Codec
            Format profile                           : High@L4.0
            Format settings, CABAC                   : Yes
            Format settings, ReFrames                : 1 frame
            Codec ID                                 : avc1
            Codec ID/Info                            : Advanced Video Coding
            Duration                                 : 5s 698ms
            Bit rate                                 : 17.4 Mbps
            Width                                    : 1 920 pixels
            Height                                   : 1 080 pixels
            Display aspect ratio                     : 16:9
            Frame rate mode                          : Variable
            Frame rate                               : 30.000 fps
            Minimum frame rate                       : 30.000 fps
            Maximum frame rate                       : 31.579 fps
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bit depth                                : 8 bits
            Scan type                                : Progressive
            Bits/(Pixel*Frame)                       : 0.279
            Stream size                              : 11.8 MiB (100%)
            Title                                    : Core Media Video
            Color primaries                          : BT.709
            Transfer characteristics                 : BT.709
            Matrix coefficients                      : BT.709
            Audio
            Format                                   : AAC
            Format/Info                              : Advanced Audio Codec
            Format profile                           : LC
            Codec ID                                 : 40
            Duration                                 : 5s 698ms
            Source duration                          : 5s 759ms
            Bit rate mode                            : Constant
            Bit rate                                 : 64.0 Kbps
            Channel(s)                               : 1 channel
            Channel positions                        : Front: C
            Sampling rate                            : 44.1 KHz
            Compression mode                         : Lossy
            Stream size                              : 44.1 KiB (0%)
            Source stream size                       : 44.5 KiB (0%)
            Title                                    : Core Media Audio
            • 3. Re: Lines & Ghosting
              A.T. Romano Level 7
              crashovaride
              Thanks for the reply with very helpful details of your Premiere Elements issue.
              1. Setting the Correct Project Preset
              a. Open Premiere Elements 13 to the Expert Workspace.
              b. Go to File Menu/New/Project and Change Settings
              c. In Change Settings, select the project preset
              NTSC
              DSLR
              1080p
              DSLR 1080p30@29.97
              Close out of there. When you do you, the new project dialog will appear with your designated
              project preset. Make sure that there is a check mark next to "Force Selected Project Setting on this Project" in the
              new project dialog. Then close out of there.
              d. Back in the Expert workspace, import your cell phone video, using the Premiere Elements 13 Add Media/Files
              and Folders/Project Assets. Drag the cell phone video from Project Assets to the Timeline Video 1/Audio 1.
              e. If there is an orange line over the Timeline content, render the Timeline content by pressing the Render button
              above the Timeline. After the Timeline content render, what is the quality of the playback of the Timeline content in the Edit area monitor?
              2. The suggested export
              Publish+Share
              Computer
              AVCHD
              with Presets = MP4 H.264 1920 x 1080p30
              If that works OK, then that is it. If problems persist, then we will have to address the issue of a variable frame rate. At that time, we will convert
              the variable frame rate to a constant 29.97 progressive frame per second frame rate using the HandBrake program.
              https://handbrake.fr/
              But, let us see what we can do without HandBrake.
              We will be watching for your results.
              Thank you.
              ATR
              • 4. Re: Lines & Ghosting
                Thanks for all your help.  Changing the presets seems to have worked and there is no signs of the lines and ghosting.  I say seems to have worked because i haven't added all the clips to the project yet and only some of the clips showed problems the last time i set it up, the majority where fine even though all being taken by the iPhone 6.
                Next question.  Is there any way to export my time line from the problematic project to this new project with the modified project settings. I've googled that i can not change the presets of an existing project and I don't really want to have to spend a couple of hours putting all the clips and soundtrack together again?
                • 5. Re: Lines & Ghosting
                  A.T. Romano Level 7
                  crashovaride
                  Thanks for the reply and the good news. Great job in follow through of the troubleshooting.
                  The Adobe party line is that you cannot change the project settings once they have been established for your project.
                  I have worked out a scheme to do this under certain conditions, but often is better to start anew rather than getting involved in the editing of the
                  Notepad document of the saved closed project whose project settings you want to change.
                  http://www.atr935.blogspot.com/2013/05/pe11-changing-project-settings-without.html
                  There are techniques for transferring content from one project file to another, but I do not believe it would be to your advantage in using them. I
                  suspect you may be transferring problems instead of solutions.
                  a. exporting your Timeline of project 1 to a file format compatible with the project settings of project 2 into which you import that export
                  b. doing a copy/paste insert between project using ClipMate (Windows Only) in conjunction with Premiere Elements Windows. I have not yet tested it
                  for Premiere Elements 13.
                  ATR Premiere Elements Troubleshooting: PE: ClipMate Copy/Paste Between Projects
                  What happens if you export the project previously set up and if you export it with the new export settings that I suggested. Does that work to give you good quality export? If so, then that is the way to go. Then import that export into a second project with new project preset suggested to join the rest of your files.
                  Please let us know if any of that worked for you. Any questions or need clarification, please let us know.
                  Thank you.
                  ATR
