1. Re: File syncing doesn't work well (steps + a solution)
jazzbangle Nov 5, 2014 2:19 AM (in response to Jerome Mouneyrac)Hi Jerome,
I am encountering the same issue that you have described. You are correct about the com.apple.geod process, and one other one which is CoreSync, an Adobe Creative Cloud process. It is also listed as unresponsive. I have to force quit that process and then re-open the CC app fresh to get it to sync again. Not sure what is triggering it, it obviously happens after CC has been running for a while.
2. Re: File syncing doesn't work well (steps + a solution)
Jerome Mouneyrac Nov 7, 2014 12:20 AM (in response to jazzbangle)Hi Jazz,
yes I noticed that coresync was not responsive too on a different day. It seems it's always either coresync either geod that need to be force quit. Just to add more info for Adobe devs, my Mac is a Macbook Pro mid 2009 with 8RAM, and I changed the HHD for a SSD. I use it as a desktop computer only. I recently reset the SMC and yosemite is a fresh upgrade from a clean Lion OS.
3. Re: File syncing doesn't work well (steps + a solution)
Ben Mordue Nov 7, 2014 4:24 AM (in response to Jerome Mouneyrac)We're currently investigating another report that may be the same issue that you are seeing. Could you send us your log files so that we can investigate further? Please zip up the entire 'CoreSync' folder at the location below and send it to me at bmordue@adobe.com.
Mac:
/Users/<username>/Library/Application Support/Adobe/CoreSync
Windows:
C:\Users\<username>\AppData\Roaming\Adobe\CoreSync
'Library' on Mac and 'AppData' on Windows are both hidden folders. Please read these pages for help on showing these folders:
http://helpx.adobe.com/x-productkb/global/show-hidden-files-folders-extensions.html (Win)
https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html (Mac)
Ben
w3843469
4. Re: File syncing doesn't work well (steps + a solution)
jazzbangle Nov 8, 2014 2:56 AM (in response to Ben Mordue)Hi Ben,
I have replied as requested. I hope you are able to make something of this, as the CoreSync freezes are still happening intermittently; again, not sure exactly why.
