1 Reply Latest reply on Nov 2, 2014 9:54 AM by A.T. Romano
    ノイズ音が入ります
    sahtrehds
      初めて質問を投稿させていただきます。
      よろしくお願いいたします。
      先日PCを買い替え、
      その際Adobe Premiere Elements 12がプリインスールされているモデルを選びました。
      音楽会などのビデオ編集を考えているのですが、
      ビデオキャプチャの際、「プッ プッ」といった、ノイズ音が不規則に入ります。
      このようなことは初めてで、あまりPCにも詳しくないため、
      調べてみても、解らずにいます。
      どうか、回答をお願いいたします
      使用OSはwin7 64bit
      ieee接続で使用しております。
        • 1. Re: ノイズ音が入ります
          A.T. Romano Level 7
          sahtrehds
          I am understanding from the translation that you are working with Premiere Elements 12 on Windows 7 64 bit and trying to capture DV or HDV data, assumed from a miniDV camcorder. Is that correct?
          If that is correct, are you using a firewire cable? Since you say "We use the IEEE connection", I assume that you are.
          Please try to capture firewire into Movie Maker to evaluate how the firewire cable/computer firewire port is working. Can you do a
          successful DV data capture firewire into Movie Maker? Can you do a successful HDV data capture firewire into HDVSplit?
          http://www.videohelp.com/tools/HDVSplit
          If we look at this in another way, are you really asking how to get rid of tape noises that you hear when you play back the captured
          video when it is in Premiere Elements? If that the case, you could try to minimize the noise with the free audio editor named Audacity
          Noise Removal - Audacity Wiki
          or try to apply one of the Premiere Elements audio effects, like DeNoiser (Windows Only).
          Please review and consider, and then let us know if we have interpreted your questions correctly.
          Thank you.
          ATR
