I cannot get past step two of download without buying an app that I do not want? Blocked plug in is persistent. Help
What? You have not provided any system information, details on what you actually are trying to download, what browser and so on. You need to do a lot better and explain properly.
Mylenium
I have a mac os-x. flash player 15 . downloads to my download storage but won't install unless I buy an app for $9.99 which I do not want.
"blocked plugin" means you are using an outdated Flash Player version; Apple/Safari will block anything older than 15.0.0.189.
You do not need to buy anything to download or install Flash Player; best use the offline installer http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
If you install using the offline installer and you still get the blocked plug-in message, do a full uninstall/reinstall. That usually solves it.
Run the uninstaller: Uninstall Flash Player | Mac OS
Then run the installer you downloaded earlier.
