0 Replies Latest reply: Nov 3, 2014 3:27 AM by ActivelyX RSS
    Solution to ERROR ITMS-9000: "Invalid Code Signing."
    ActivelyX Community Member
      I am using FlexSDK 4.13 and AIR SDK 15.0.302. I installed the FlexSDK and AIR SDK with the Apache Flex installation binary on a Windows Vista 64-bit machine.
      I can build and run an ad-hoc version of my iOS app on an iPhone 4 (iOS 8.0.2) and iPad 2 (iOS 8.1). When I build a release version for the iTunes App Store, and submit it with the Xcode Application Loader. I get the error.
      ERROR ITMS-9000: "Invalid Code Signing. The executable, Payload/YourApp.app/YourApp, must be signed with the certificate that is contained in the provisioning profile."
      I'm using a Mac to submit my app. It is running OS X 10.10 Yosemite and Xcode version 6.1. The Application Loader is version 3.0.
      I suspect that the adt command no longer creates a payload with the correct entitlements. This post illustrates how I resigned my app so that the iTunes App Store would accept it.
      First, I copied my IPA file to my iMac. Then I changed directories to the location of my IPA file.
      Open a text editor and create a file with the name, entitlements.plist.
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
      <plist version="1.0">
      <dict>
      <key>application-identifier</key>
      <string>XAXAXAXAXA.com.yourapp.yourappmobile</string>
      <key>get-task-allow</key>
      <false/>
      <key>keychain-access-groups</key>
      <array>
      </array>
      </dict>
      </plist>
      Save this file.
      Start a terminal session. Then type in the following commands.
      unzip YourApp-app-store.ipa
      cp ~/Downloads/YourApp.mobileprovision Payload/YourApp.app/embedded.mobileprovision
      codesign -f -s "iPhone Distribution: YOUR COMPANY NAME (XAXAXAXAXA)" --entitlements Payload/YourApp.app/entitlements.plist Payload/YourApp.app
      zip -qry YourApp-resigned.ipa Payload/
      Note that codesign uses the full key name of your code signing certificate.
      Now you can submit YourApp-resigned.ipa to the iTunes App Store.
      I've seen some people have success with the iReSign App, which you can find at the following URL. I prefer the command line.
      https://github.com/maciekish/iReSign
