1. Re: Typekit web fonts only partially load in IE
Liz, Typekit Support Nov 4, 2014 9:00 AM (in response to linseyfree)Hi linseyfree,
I am sorry that you've been having trouble with your font loading! We didn't receive an email from you in Typekit Support; I will look into what happened there.
I have been emailing with one of your colleagues (Tom S), however, and I believe this problem has been sorted out. If you still see trouble with the font loading, however, please run the tests at the end of this post in IE 9 or 10 and we can look into it further for you.
Best,
-- liz
Use the web developer tools in the browser to look at your site's assets, and take a screenshot of the timeline for Typekit.
1. Clear your site cache so that the Typekit files are requested from the network again.
2. Select the network tab in the developer tools and keep it open.
3. Go to the page that's giving you trouble. Verify that it loads and that the fonts still aren't loading properly.
4. In the network tab, scroll down until you find the requests from Typekit; there should be a JavaScript file and a CSS file.
> take a screenshot
5. Select the JS filename, then select the Headers tab that appears.
6. Resize the window so that all header info rows are visible.
> take a screenshot
7. Select the HTML tab. Is the font marked as "wf-active" in the font events on the HTML tag?
> take a screenshot
