2 Replies Latest reply on Nov 11, 2014 7:44 AM by Fat Max
    First Topic Missing from TOC
    Fat Max
      Windows 7 Ultimate
      Robohelp V7.03
      When I generate Printed Documentation to a standard Word doc. Chapter 1 and it's associated topic are missing from the TOC:
      The TOC begins with Chapter 2:
      For grins and giggles I generated the documentation with ONLY Chapter 1 selected to see what would happen; it shows up in the TOC just fine:
      In either case, the topic is published in the body of the text just as it should be.  The only issue is that Chapter 1 doesn't make it into the TOC when I generate the whole thing.
      I have no conditional Build Expressions.
      The Topic properties are set for it to be included in the TOC.
      There is only one TOC.
      Ham-handed efforts to simply add it manually to the TOC in Word failed miserably.
      Is there some sort of secret setting I am missing?  How do I get the TOC to accept Chapter 1 along with the other chapters???  I would be most grateful for any assistance.  Thanks in advance.
      Scott
        • 1. Re: First Topic Missing from TOC
          Have you tried clicking to the right of the TOC and selecting Update Field?
          @petergrainge
          • 2. Re: First Topic Missing from TOC
            Fat Max Level 1
            Thanks for the response, Peter.  I did indeed update the table, to no effect.
            However, I found a work-around for my issue.  In the Word 2003 document that gets produced, I am able to reconfigure the TOC to generate based on the outline rather than whatever it currently does.
            Highlight TOC >> R Click Edit Field >> Select Table of Contents Button >> Options >> Select "Outline Levels" check Box >> OK >> OK
            Select "Yes" in the message to replace the TOC, and there it is:
            I still believe there must be some arcane setting in Robohelp that will make the TOC generate properly because I have never had this issue before.
