3 Replies Latest reply on Nov 4, 2014 11:33 AM by A.T. Romano
    Answer to the ' No disk in drive E ' problem.
    Veeblefester Level 1
      Win 8.1
      You need administrative privileges.
      If you do not have a drive E.
      Control Panel > Administrative Tools > Computer Management > Maximize.
      In left pane, Storage > Disk Management > Wait for the window to populate.
      In the right pane, lower half, right click on drive E > Change Drive Letter and Paths…
      ‘Remove’ drive E.
      Close back to desktop and reboot.
      Should be similar for other flavors of  Windows.
        • 1. Re: Answer to the ' No disk in drive E ' problem.
          A.T. Romano Level 7
          Veeblefester
          With what version of Premiere Elements on Windows 8.1 64 bit are you having this "No disk in drive E" issue?
          In your suggested fix, you start with
          But, where are you supposed to have a drive E in Manage/Disc Management/ if you do not have drive E in
          the first place in "This PC" display of drives? If I do not see an E drive in "My PC" display, I do not see an E drive
          in Disc Management with the drives that I do see in "My PC" display.
          ATR
          • 2. Re: Answer to the ' No disk in drive E ' problem.
            Please follow the instruction.
            No drive E: showed up in My PC (File Explorer).
            However, drive E: did show up in 'Storage > Disk Management'.
            This solution quickly solved the problem!
            • 3. Re: Answer to the ' No disk in drive E ' problem.
              A.T. Romano Level 7
              Veeblefester
              Thank you for the clarification.
              What version of Premiere Elements were you working with when you ran into this No disk in drive E issue?
              Do you have any idea if the E drive existed in Disc Management before your Premiere Elements was installed?
              I have not run into this issue and just wanted to clarify the above since it is getting to be a more frequent question
              in this forum.
              Thanks.
              ATR
