1 Reply Latest reply on Nov 3, 2014 10:06 PM by greg minshall
    after import, image from camera replaced with old (and incorrect) image
    greg minshall
      i imported photos this morning.  maybe 200.  into Lightroom 5.6 (with
      camera raw 8.6, running on macosx 10.9.5; see below for "system info").  the images came from my
      Leica M Typ 240, and were in raw format.  after importing the images, i
      went through them in my first editing pass.
      going through, image 1867 ("L1001867.DNG") in LR was *not* the same as
      image 1867 on my camera, but was, rather, an image (no longer on the
      card in my camera) from 8 months ago in China.
      the image on the camera was from 07.10.2014 15:49.15 (following one
      taken at 15:49:07, which *did* show up in LR).  the *meta* data in LR
      appears correct for the image from the camera (i.e, shows a date of
      07.10.2014, has likely exposure information, etc.), but the image itself
      is the wrong image.
      the image in LR *may* have been one i deleted (in LR), though i don't
      know that for sure.  if i *did* delete it, i deleted it months ago.
      the LR image was shot on 22.02.2014 at 02:51-02:52 (i typically don't
      change the clock).  while i don't know for sure the image number of the
      image in LR, it *appears* to be image 1419.
      obviously, this is fairly worrying (as i count of LR to keep my
      inventory!).  what can i do to help you troubleshoot this?  what can you
      tell me about what is happening?
      here is what "help:system info" says:
      Lightroom version: 5.6 [974614]
      License type: Perpetual
      Operating system: Mac OS 10
      Version: 10.9 [5]
      Application architecture: x64
      Logical processor count: 4
      Processor speed: 2.9 GHz
      Built-in memory: 8192.0 MB
      Real memory available to Lightroom: 8192.0 MB
      Real memory used by Lightroom: 1673.7 MB (20.4%)
      Virtual memory used by Lightroom: 3555.8 MB
      Memory cache size: 1608.3 MB
      Maximum thread count used by Camera Raw: 2
      Displays: 1) 2560x1600
      Application folder: /Applications
      Library Path: /Users/minshall/Pictures/Lightroom/Lightroom 5 Catalog.lrcat
      Settings Folder: /Users/minshall/Library/Application Support/Adobe/Lightroom
      Installed Plugins:
      1) Behance
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) Leica Tether Plugin
      6) Nikon Tether Plugin
      7) Photoshelter Archive Publisher
      Config.lua flags: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Built-in Output
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: Intel HD Graphics 4000 OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: Intel Inc.
      GL_VERSION: 2.1 INTEL-8.28.32
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float
      GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers
      GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced
      GL_ARB_fragment_program GL_ARB_fragment_program_shadow
      GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB
      GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays
      GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query
      GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite
      GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects
      GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow
      GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression
      GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map
      GL_ARB_texture_env_add GL_ARB_texture_env_combine
      GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float
      GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two
      GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix
      GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object
      GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr
      GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate
      GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract
      GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker
      GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord
      GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample
      GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB
      GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4
      GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float
      GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color
      GL_EXT_separate_specular_color GL_EXT_shadow_funcs
      GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array
      GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc
      GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic
      GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle
      GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB
      GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback
      GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil
      GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence
      GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render
      GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer
      GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector
      GL_APPLE_texture_range GL_APPLE_transform_hint
      GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range
      GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators
      GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3
      GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip
      GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp
      GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection
      GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp
      GL_SGIS_texture_lod
