4 Replies Latest reply on Nov 9, 2014 3:19 PM by Visualart.be Branched from an earlier discussion.
    After Effects not reporting virtual cores
    Visualart.be Level 1
      I'm currently installing my new workstation and came across the same issue however, I have 36 physical cores, 72 virtual cores but only 36 are visible by AE.
      Using latest CC2014.
        • 1. Re: After Effects not reporting virtual cores
          Dave LaRonde Level 6
          Relax.  It's not that important.  AE doesn't use virtual processors.
          As Mylenium pointed out in a previous thread, AE makes spotty use of the Render Multiple Frames Simultaneously feature, because not all effects can use it -- they only use one core.  If you have a lot of effects stacked on a layer, and only ONE of those effects is limited to a single processor, AE will use a single processor.
          If you wish to use multiprocessing if at all possible, an acceptable rule of thumb is to allocate 1/4 of your PHYSICAL processors  to the OS and other applications, and let AE have the others, with about 4 gigs memory assigned per processor.  If it's able to use multiprocessing, it will, but it's a crap shoot.
          • 2. Re: After Effects not reporting virtual cores
            ok, fair enough, brings me down to my next question, how can I assign more then 6gb (max selectable in dropdown) per process ? I got 256GB at hand.
            Most of the time I don't use all cores assigned to AE anyhow (cause it's plane silly to have like 35 instances of ae running on your system)
            About time AE gets some proper multithreading doh...
            • 3. Re: After Effects not reporting virtual cores
              Todd_Kopriva Level 8
              Those values in the menu are under your control. You can change them in the preferences file. The line that defines the 6GB entry looks like this:
              "MP - Allocation Per Background Process v2 Preset VI" = "6.000000"
              • 4. Re: After Effects not reporting virtual cores
                Hi Todd, thanks for the feedback, managed to change it.
                However onto next thing when I look at the resources AE is using it's far from using the potential of my new workstation.
                Are there specific things I should look at or change to get AE more up to speed ?
                Current hardware setup:
                2x Intel Xeon E5-2699v3 @2.30Ghz (2x18core)
                256GB Ram
                System disk: 2x120gb SSD RAID0
                Scratch disk: 2x120gb SSD RAID0
                Workdisk: 4x512GB SSD RAID0
                Video: 2x GTX980
                Windows 8.1 Pro
                So for example, I'm loading in a 4K DNG sequence, I would expect Disk Usage would get up to maximum speed, however in Resource monitor it shows it's using only a mere 10MB/sec
                For this example CPU & RAM are behaving quite normal as I don't expect it to be CPU intensive or Fill up my RAM completely.
