1 Reply Latest reply on Nov 5, 2014 1:01 PM by radzmar
    Calculate numeric fields
    tallanwt Level 1
      I have a form with two numeric fields (gross_wt, tare_wt). I have a third field fill_wt (set as calculated-read only)
      topmostSubform.Page1.Fill_Wt::calculate - (FormCalc, client)
      fill_wt=gross_wt-tare_wt
      When I open the pdf form, I get
      Pls. advise on correct scripting.
      Using Acrobat XI Pro, Livecycle ES4
        • 1. Re: Calculate numeric fields
          radzmar Adobe Community Professional & MVP
          First, you should add spaces to your script to make it more readable.
          Then you should check that you've used the exact naming of your fields (names are casesensitive).
          I can see that the field is named Fill_Wt but in your script you've used fill_wt so I assume the other fields have use uppercase letters included.
