I converted a RoboHelp 9 project to RoboHelp 10 and noticed that Column 1 in all tables has a preferred width setting of 93% and it is not allowing me to remove this setting. When I uncheck the Preferred width checkbox and click OK, then go back to the Table Properties>Column tab, the Preferred width checkbox is checked again with a width setting of 93%. The column width is not specified in the HTML, it is set to fit to the contents (<col />). The odd thing is that Column 1 only displays this way in Design view. When previewing and publishing the topic, it displays correctly (fits to contents). This however makes editing content in tables extremely difficult in Design view. Any assistance is appreciated.
Check the table is set to 100% and the columns add to that.
The table is not set to 100%. When I set it to 100%, there is no change in behavior.
Sorry about the delay. Can you import that topic into a new project, test the problem is still there and then send it to me?
See the Contact page on my site.
I created a new blank project and imported the topic. Again, the first column of all tables are displaying in Design view with a width of 93%. However, when viewing table properties, Column 1 does not have a the Preferred width set at 93% as it does in the original project. Unfortunately, I am unable to send you a copy of the project.
If it doesn't have a width setting of 93%, where are you finding it is set to 93%?
There was a bug in Rh10 with table widths and I cannot recall the exact details without some testing. I think it was along the lines that in design view there would be problems unless the columns had a width and so did the table.
I do know that once I set up tables in a specific way, they were also fine in design view. Post back if stuck and I will look but it may not be for a few days.
