1. Re: Upgraded to Windows 8.1 broke Flash/AIR/ANEs
Mark.fromOP Nov 5, 2014 12:55 AM (in response to Mark.fromOP)Well switched back to Windows 7 and all seems to be working but had the same issue at first. My guess is that it was caused by the old files looking for something from the OLD machine in the C:\Users\UserName\AppData\Local\Temp folder. When this error originally came I up I went and found the files it was asking for on the old machine and copied to the new. This I believe is where the error above started causing issues, the .fla was looking for some sort of old extracted versions of the file which it was not finding due to new drive paths and only when I switched to 7 and instead of copying old files over, I deleted the folder it was looking for, did I resolve this although I am still not 100% certain that was the case. I also had issues with Flash not recognizing plugged in devices when trying to publish to device and going back to 7 solved this as well so I think Ill stick to 7 for now till 10 comes out but I wrote this up in case someone one day runs int this problem.
