4 Replies Latest reply on Jul 10, 2016 7:55 AM by benjamin_weiler
    Painting Process Documentation: Stamp Visible, Move to layer Set and hide
    benjamin_weiler Level 2
      I like to capture my screen while painting and when I am done I make an animated GIF from these "process shots". I am trying to automatize the process and I have managed to come up with this which meets my needs:
      #target photoshop
      app.bringToFront();
      // Stamp visible Layers
      var idMrgV = charIDToTypeID( "MrgV" );
          var desc2 = new ActionDescriptor();
          var idDplc = charIDToTypeID( "Dplc" );
          desc2.putBoolean( idDplc, true );
      executeAction( idMrgV, desc2, DialogModes.NO );
      // Move Active Layer to the Bottom of LayerSet "process"
      var activeLayer = activeDocument.activeLayer;
          var processFolder = activeDocument.layerSets.getByName("process")
          activeDocument.activeLayer.moveToEnd (processFolder);
      Now I would like to add a conditional to check, whether or not the "process" layer-set exists and if it does not, create it. This should look something like this:
      // Process Image Capture
      // V 0.3
      // PIC Stamps Visible (creates a new layer that combines all visible information in flattened form) and moves that to a "process" Layer Set.
      // Layer is then hidden.
      // If Layer Set is not there, it will be created.
      #target photoshop
      app.bringToFront();
      // Check for "Process" Layer-Set on root. Create, in case it is not present.
      if (!activeDocument.layerSets.getByName("process")) {
           activeDocument.LayerSets.add();
           activeDocument.LayerSets.name = "process";
      /* else {
          activeDocument.activeLayer.visibility = false;
      The condition seems to be what causes the problem, but I have no idea how to fix it. Can somebody help?
        • 1. Re: Painting Process Documentation: Stamp Visible, Move to layer Set and hide
          xbytor2 Level 4
          Capitalization problems.
          These lines:
          Should be
              activeDocument.layerSets.add();
              activeDocument.layerSets.name = "process";
          Not saying there is nothing else wrong, though....
          • 2. Re: Painting Process Documentation: Stamp Visible, Move to layer Set and hide
            Do you perchance know what kind of value would be returned by .layerSets.getByName("process") if there is no such Layer Set?
            Is it undefined? False? Null?
            How would I go about finding out?
            • 3. Re: Painting Process Documentation: Stamp Visible, Move to layer Set and hide
              Ok, here is the script that does the deed, it requires an additional function to catch what getByName() returns.
              // V 1.0
              #target photoshop
              app.bringToFront();
              if (!hasRootLayer("process")) {
                  var addedLayer = activeDocument.layerSets.add();
                  addedLayer.name = "process";
              // Function to check whether "process" layer exists, passes result back as a boolean
                  function hasRootLayer(layerName){
                  var hasProcessLayer = false;
                  try{
                      hasProcessLayer = (typeof activeDocument.layerSets.getByName(layerName) != "undefined");
                  }catch(e){}
                  return hasProcessLayer;
              • 4. Re: Painting Process Documentation: Stamp Visible, Move to layer Set and hide
                I upgraded this script to use layer IDs and it now does the following:
                1. Takes the shots of your work
                2. Puts them in a layer-set called "process
                3. Hides  the last shot you took
                4. Returns to the layer it was called from, ninja-style
                You can then make easily make an animated GIF from the layer in the "process" layer-set, presto.
                Enjoy Version 1.3:
                // V 1.3
                // If Process Layer Set is not there, it will be created.
                // Now remembers what layerSet or Layer it was called from and returns to it after placing process image
                // Fluff removed
                #target photoshop
                app.bringToFront();
                // Container to hold Layer ID of active Layer at moment of script execution
                var callLayer =  getActiveLayerId(activeDocument.activeLayer);
                alert(callLayer, "calling Layer:");
                var descMerge = new ActionDescriptor();
                descMerge.putBoolean( idDplc, true );
                executeAction( idMrgV, descMerge, DialogModes.NO );
                // Move Active Layer to the Bottom of LayerSet "process" and hide
                var activeLyr = activeDocument.activeLayer;
                var processFolder = activeDocument.layerSets.getByName("process");
                activeDocument.activeLayer.moveToBeginning (processFolder);
                activeDocument.activeLayer.visible = false;
                // Return Focus to Layer from which Action was called
                makeActiveByID(callLayer);
                // Check whether "process" layerSet exists, passes result back as a boolean
                    try{
                    }catch(e){}
                // Get Layer ID
                function getActiveLayerId() {
                    var ref = new ActionReference();
                    ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "LyrI" ));
                    ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    return executeActionGet(ref).getInteger( stringIDToTypeID( "layerID" ) );
                // Activate Layer by ID
                function makeActiveByID( id ){
                    try{
                        var desc = new ActionDescriptor();
                            ref.putIdentifier( charIDToTypeID( "Lyr " ), id );
                        desc.putReference( charIDToTypeID( "null" ), ref );
                        desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                        executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
                        return activeDocument.activeLayer;
                    }catch(e){}
