1 Reply Latest reply on Nov 5, 2014 2:52 PM by A.T. Romano
    I want to start a project with AVCHD footage from 2 devices. some frame size is 1280x720 at 50fps. The other is 1920x1080at 25fps. I want to use adoTV. I need to get the setting right before I start, and I dont really understand how to get the best result
    settingconfused
      I want to start a project with AVCHD video footage from 2 devices. Some frames are 1280x 720 at 50fps. The other is 1920x1080 at 25fps.
      I will be using elements 13 and I need to get the settings right before I start. I don't understand how to get the best results for a good quality DVD (not Blue Ray) and play it on my Pal standard TV.
      I need to be told in simple terms as my knowledge of the different formats etc is very limited. ( I'm OK with the editing though!
        • 1. Re: I want to start a project with AVCHD footage from 2 devices. some frame size is 1280x720 at 50fps. The other is 1920x1080at 25fps. I want to use adoTV. I need to get the setting right before I start, and I dont really understand how to get the best re
          A.T. Romano Level 7
          settingconfused
          Because of missing information in your problem description, you will see me using "assume"....we can fine tune the "assume" with your
          reply to the post that I am writing now.
          For now I am assuming that your Premiere Elements 13 is on Windows 7, 8, or 8.1 64 bit. I will further assume that your
          1920 x 1080 is @ 25 progressive frames per second.
          a. Open Premiere Elements 13 to its Expert workspace.
          b. Go to File Menu/New/Project and Change Settings
          c. In Change Settings, set the project preset to
          PAL
          DSLR
          1080p
          DSLR 1080p25
          Close out of there. When you do, you will be greeted by the new project dialog with the new project preset setting.
          Make sure that you have a check mark next to "Force Selected Project Settings on this Project" in that new project dialog.
          Close out of there.
          d. Back in the Expert workspace, import your 1920 x 1080 @ 25 progressive frames per second into the project using the project's
          Add Media/Files and Folders/Project Assets. From Project Assets, drag the video to the Timeline Video Track 1/Audio Track 1.
          e. Now import your 1280 x 720 @ 50 progressive frames per second.
          Render the Timeline by pressing the Render button above the Timeline. After the
          render is complete, what does the playback in the Edit area monitor look like video and audio quality wise? Are there going to
          me menus?
          f. When you arrive at Publish+Share/Disc/Blu-ray disc, consider the reset = H.264 1920 x 1080i PAL Dolby.
          What is the result when you play back your Premiere Elements 13 Blu-ray disc format on Blu-ray disc?
          Any questions or need clarification, please do not hesitate to ask.
          Thanks.
          ATR
          Add On...See if you can find out for me whether your 1920 x 1080 source is recorded at 25 interlaced or 25 progressive frames per second. Brand/model/settings of camera that recorded the video might give us the information needed. Right now I am assuming 1080p instead of 1080i.
