1 Reply Latest reply on Mar 23, 2007 8:12 AM by tippirue
    mxmlc - fails immediately when executing at command prompt
    tippirue
      Yes, I am running flex 2 with java 1.6.
      I am able to write and run applications using the Flex Builder 2 IDE with no problem.
      Wanted to compile style sheet for use at runtime.
      Worked through the jvm.config setting without issue.
      When i run mxmlc from the command prompt, Windows prompts with "JAR Launcher has encountered a problem and needs to close. We are sorry for the inconvenience."
      I launched VS debugger, where I was able to get the violation, Unhandled exception at 0x5c62696c in mxmlc.exe: 0xC0000005: Access violation reading location 0x5c62696c.
      Any insight or help is appreciated.
