7 Replies Latest reply: Nov 6, 2014 6:12 AM by kglad RSS
    Removing a MovieClip by Clicking
    navigator81 Community Member
      I want to Remove a Movie Clip loaded from an Array by just Clicking it.
      Here is how I loaded them
      function load1(Event:MouseEvent):void
        addChild(notes[0]);
        notes[0].x = 100;
        notes[0].y = 100;
      I have three Movie Clips in this Array which are loaded on a condition.
      Once one of the MovieClip is on the Screen , I want to remove it by just clicking anywhere on this Movie Clip , How can I do this ?
        • 1. Re: Removing a MovieClip by Clicking
          kglad CommunityMVP
          use:
            addChild(notes[0]);
            notes[0].x = 100;
            notes[0].y = 100;
          notes[0].addEventListener(MouseEvent.CLICK,clickF);
          function clickF(e:MouseEvent):void{
          removeChild(e.currentTarget);  // notes[0] still exists though and still has a mouse listener.  if you want to remove it from the notes array and ready it for gc, remove the listener and use the splice() method of arrays
          • 2. Re: Removing a MovieClip by Clicking
            Thanks a lot kglad , I really appreciate your help with the code , that really helps as I am really new to AS3.
            I tried this but I am getting this Error
            Scene 1, Layer 'AS', Frame 2, Line 937, Column 18 1118: Implicit coercion of a value with static type Object to a possibly unrelated type flash.display:DisplayObject.
            How do I fix that ?
            • 3. Re: Removing a MovieClip by Clicking
              kglad CommunityMVP
              what's line 937?
              • 4. Re: Removing a MovieClip by Clicking
                kglad,
                Line 937 Contains the Variable that I am incrementing with each Child added on to the stage
                popcount ++;
                Here is the Whole Function
                  addChild(notes[0]);
                  notes[0].x = 100;
                  notes[0].y = 100;
                  popcount ++;
                  trace("Counter Value:" + popcount);
                  if ( popcount == 2)
                    btn_nxt.addEventListener(MouseEvent.CLICK , nextframepop1);
                • 5. Re: Removing a MovieClip by Clicking
                  Hi ,
                  I am trying to Remove the Child (correct) from the stage and I am using this Event Listener function close to call this remove action.
                  if the Answer is Correct , this new Movie Clip name Correct should show up and when clicked , it should move to next Frame, otherwise another Movie Clip Wron Answer should pop up and stay on the same frame.
                  Here is my Code , but for some reason , its not working
                  ////// CODE ///////
                  LISTENER /////////
                     if(e.currentTarget == rb1){ /// Checking the Radio Button Selection
                     score++;  /// Correct Answer will add 1 to Score.
                      addChild(correct);     //// THIS IS THE MOVE CLIP I WANT TO SHOW
                      correct.x = 296;
                      correct.y = 263;
                      correct.addEventListener(MouseEvent.CLICK,close); /// INSIDE THIS CALL , I AM ADDING AN EVENT LISTENER TO SEE IF THE MOVIE CLIP IS CLICKED, IF YES , IT SHOULD CALL THE FUNCTION "CLOSE" Mentioned Below.
                      trace("Correct Answer");
                      trace(score);
                  FUNCTION NAME CLOSE
                  function close(e:MouseEvent):void
                     stage.removeChild(e.target);
                  Here is the Error that I get
                  //// ERROR ///////////
                  Scene 1, Layer 'AS', Frame 2, Line 962, Column 23 1118: Implicit coercion of a value with static type Object to a possibly unrelated type flash.display:DisplayObject.
                  • 6. Re: Removing a MovieClip by Clicking
                    kglad CommunityMVP
                    you must have something on stage called popcount.  use a different name and make sure you declare it:
                    var popcount:int;
                    • 7. Re: Removing a MovieClip by Clicking
                      kglad CommunityMVP
                      use the code i suggested,
