XML Error: Code = invalid Field = response SubCode = range
Adobe Connect forum Nov 5, 2014 3:41 PMHi all!
I am using The AdobeConnect XML API 9. I am receiving a random error when I use the API to register a new guest. Here is the code I am using.
XmlNodeList fields = Request("event-registration-details", "sco-id=" + event_sco_id).SelectNodes("results/event-fields/field");
string city_id = "", state_id = "", title_id = "", school_id = "", zip_id = "", phone_id = "";
foreach (XmlNode node in fields)
if (node.SelectSingleNode("description").InnerText == "City")
city_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (node.SelectSingleNode("description").InnerText == "State")
state_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (node.SelectSingleNode("description").InnerText == "Title")
title_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (node.SelectSingleNode("description").InnerText == "School/Company Name")
school_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (node.SelectSingleNode("description").InnerText == "Zip")
zip_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (node.SelectSingleNode("description").InnerText == "Phone Number")
phone_id = node.Attributes.GetNamedItem("interaction-id").Value;
if (_bzsession != "")
Logout();
var eventDoc = Request("event-register",
"sco-id=" + event_sco_id + "&login=" + email + "&password=mimio&password-verify=mimio&first-name=" + first_name + "&last-name=" + last_name + "&interaction-id=" + city_id + "&response=" + city + "&interaction-id=" + state_id + "&response=" + state + "&interaction-id=" + title_id + "&response=" + title + "&interaction-id=" + school_id + "&response=" + school + "&interaction-id=" + zip_id + "&response=" + zip + "&interaction-id=" + phone_id + "&response=" + phone, false);
return eventDoc.SelectSingleNode("results/status");
So basically I am calling event-registration-details to get the interaction ids for the event's questions. I am then logging out because the event register call failed if still logged in. Finally I call event-register.
The XML error I randomly get states the code = invalid, the Field = response and the SubCode = range.
I do not see any difference between the events that don't get this error and the events that do.
Any ideas would be greatly appreciated. Adobe support is stumped.
Thanks!
Chris
