Adobe Creative Cloud will not Sync Any Files/Folders (MAC OSX)
mddaz Nov 5, 2014 4:54 PMI am posting this more as a guide for people having similar issues than I am a question, as it has already been resolved but I could not find this answer anywhere on the forums.
Here was my situation:
After a fresh install of a completely empty creative cloud account, Creative Cloud is unable to sync any files or folders.
In order to troubleshoot the issue, I created a single <folder> and 1 file (Instructions.txt) inside my Creative Cloud Folder that needed to sync. Remember, this was a brand new install on a brand new account.
I then attempted to sync.
Here is an excerpt from my CoreSync log, so that you can see the errors being generated:
20141105-115144.374: Job 'CreativeCloudFiles': Analyze Finished OK 20141105-115144.374: ===== 2014-11-05 11:51:44: Job 'CreativeCloudFiles': SYNC started by Job start on computer 'TSDMAC01' ===== 20141105-115144.374: CreativeCloudFiles: /Users/<me>/Creative Cloud Files <-> acsl://scss.adobesc.com/files (acsl://scss.adobesc.com:80/files) [DirectDest], ConflictOnDiffItemsNoCommonHistory, CleanupOldGens=24m, TmpDest, SameBeforeSyncAsInAnalyze, DetectMovesAndRenames, DetectFolderMoves, WorkerThreads=8, FileLinksDrill, CopyCreateTime, ResolveConflicts=RightToLeft, RenamesLosingFile 20141105-115144.416: Start UL: /Instructions.txt (New) 20141105-115144.436: Starting a batch of 1 20141105-115144.436: SqlStatement::prepare: error is 'SQL logic error or missing database' with query 'INSERT INTO pending_requests (created, item_id, f_path, f_name, ev_type, request_id)VALUES (:eventTime,:itemId,:path,:name,:eventType,:requestId)' 20141105-115144.438: Start UL: /<folder> (Del) 20141105-115144.439: AcslSvcFS::CreatePendingRequestEntry: Error adding pending entry with name '/files/Instructions.txt': SQL logic error or missing database 20141105-115144.442: Copy New '/Users/<me>/Creative Cloud Files/Instructions.txt' -> 'acsl://scss.adobesc.com:80/files/Instructions.txt' - ERROR: Copying file: Error adding pending entry with name '/files/Instructions.txt': SQL logic error or missing database 20141105-115144.442: Finish UL: /Instructions.txt (New): Copying file: Error adding pending entry with name '/files/Instructions.txt': SQL logic error or missing database 20141105-115144.458: SqlStatement::prepare: error is 'SQL logic error or missing database' with query 'INSERT INTO pending_requests (created, item_id, f_path, f_name, ev_type, request_id)VALUES (:eventTime,:itemId,:path,:name,:eventType,:requestId)' 20141105-115144.459: AcslSvcFS::CreatePendingRequestEntry: Error adding pending entry with name '/files/<folder>': SQL logic error or missing database 20141105-115144.459: Ending a batch of 1 20141105-115144.459: Finish UL: /<folder> (Del): No error
I called Adobe Customer Support, and after explaining the situation, was first instructed on how to save a file to my Creative Cloud folder. Just a note to Adobe, when a customer sends you a detailed log file and tells you they have already tried certain steps from the forums, don't start at using Adobe 101.
Customer service insisted that I try deleting options.tix again. I did so, following the instruction posted here: Re: I can't sync to my files In the CC desktop app
This did not work.
Support then requested that I navigate to /Users/<my username>/Library/Application\ Support/Adobe/ and rename the "CoreSync" folder to "Coresyncold".
Upon doing, killing "Adobe Creative Cloud" and "CoreSync" processes, and restarting the "Adobe Creative Cloud" Application, all syncing functionality worked correctly.
To summarize, this fixed the issue:
- Rename "CoreSync" to "Coresyncold" (Functionally, the same as deleting it)
- Kill "Adobe Creative Cloud" and "CoreSync" Processes
- Restart "Adobe Creative Cloud"
Here is the process as terminal commands:
mv ~/Library/Application\ Support/Adobe/CoreSync ~/Library/Application\ Support/Adobe/CoreSyncOld killall Creative\ Cloud killall CoreSync open -a Creative\ Cloud
Good Luck,
Michael
