3 Replies Latest reply on Aug 10, 2006 8:33 PM by inlineblue
    Asynchronous Calls
    pcopeland2
      We have been using Flex 2 for a for the last month to build our first application. We've built distributed applications using both Corba and more recently J2EE.
      One aspect of Flex Data Servies that we are finding problamatic is that all remote calls are done asynchonously. We can understadn that in some cases that can be desirable - but but it creates much more complex code for the vast majority of cases. Normally I want to create a business delegate object that executes a method on the server and returns a value or set of objects back to me. Under the current model any time I need to interact with the server objects I need to fragment my code to await the response.
      Has anyone else found this an issues - or developed some patterns or techniques to address this?
      Cheers
      Philip
      pcopeland@avoka.com
        • 1. Re: Asynchronous Calls
          aBill
          Hi
          Flex provides different levels to handle asynchonous calls. I think you already know, but I am still going to repeat them. Call can be handle as service result, method result or request result..
          example:
          Service level
          <RemoteObject destination="getMyDataService" result="handleServiceResult(event)">
          method level
          <method name="getMyItem" result="handleMethodResult(event)"/>
          request level
          var responder1:MyResponder = new MyResponder(datagrid1);
          var token1:AsyncToken = remoteObject.getMyItems("all java books");
          token1.responder = responder1;
          var responder2:MyResponder = new MyResponder(datagrid2);
          var token2:AsyncToken = remoteObject.getMyItems("all actionscript books");
          token2.responder = responder2;
          In the request level example, the blocked calls need much more time to render data in 2 datagrids, but asynchonous one take advantage to cut the time in half
          I cannot say asynchonous call better, but it does have its merit point, and Flex different levels of handling asynchonous call make the code easier already for different situations.
          If you can provide your scenario which async call is hard to implement, it would be great to share.
          William Chan
          William Chan
          • 2. Re: Asynchronous Calls
            pcopeland2 Level 1
            I agree that for populating forms and grids its nice to do this asynchronously. However when I want to do transactions not having a synchronous call is not nice and leads to significently more complex client side code than is necesssary.
            A simple example is when I need to perform 2 remote calls - and the second call needs to be executed after the first call completes. Instead of having some simple code in one method that calls both remote methods my client side code becomes fragmented - making the logic more difficult to follow. Our concern is that as the size and complextity of the app grows this is just unnecessay complexity.
            We are just trying to understand why its been done this way (and the simpler case ignored) and if we have missed something obvious.
            Phil
            • 3. Re: Asynchronous Calls
              inlineblue Level 1
              The reason that all remote calls are asynchronous is because the Flash Player is essentially single-threaded. Yes, the remote calls happen on another thread, but you can't make use of it. All UI processing is done by a single thread, so a blocking call will freeze up the entire app.
              Yes, this does make certain processing more difficult. You'll have to get used to "chaining" your calls in those cases where the order of calls is important. You can implement a class to do this for you (ie. provide a list of functions to call and then have the callback of one function call the next function).
