2 Replies Latest reply on Nov 6, 2014 11:14 PM by LearnIndesignScripting
    How to add a  progress bar into a function which called itself recursively
        • 1. Re: How to add a  progress bar into a function which called itself recursively
          AnshulJain19 Adobe Employee
          You can use ScriptUI to create progressbar in your script. Following is an example on how progress bar can be created:
          var progressRes = "dialog \
            text: 'Auto Collection',\
            preferredSize: [450,-1],\
            view1: Group\
            alignment: 'fill', orientation: 'column',\
            _label: StaticText{ alignment: 'left', text: 'Examining images...' },\
            _progress: Progressbar{ alignment: 'fill', properties: { name: 'progress' } },\
            _startAndCancel: Button{ text: 'Start',\
            started: false, cancelled: false,\
            properties: { name: 'cancel' }\
          var progressWindow = new Window( progressRes );
          progressWindow.progressBar = progressWindow.findElement( 'progress' );
          progressWindow.cancelButton = progressWindow.findElement( 'cancel' );
          progressWindow.cancelButton.onClick = function()
            if (this.started)
            this.cancelled = true;
            else {
            this.started = true;
            this.text = "Cancel";
            this.window.startWork();
          // Start the 'work' when the start button is clicked
          progressWindow.startWork = function()
            while (this.progressBar.value < this.progressBar.maxvalue &&
              ! this.cancelButton.cancelled)
            this.progressBar.value = this.progressBar.value + 1;
            this.update();
            this.workFunction();
            progressWindow.close( this.cancelButton.cancelled ? 1 : 2 );
          progressWindow.workFunction = function()
            $.sleep(500);
          progressWindow.setMax = function( maxval )
            progressWindow.progressBar.maxvalue = maxval;
            progressWindow.progressBar.value = 0;
          progressWindow.setText = function( label )
            progressWindow.children[0]['_label'].text = label;
          //------------------------testing code
          function progressTest()
            progressWindow.setMax(8);
            var result = progressWindow.show();
            // Do something with result...
          progressTest();
          -Anshul
          • 2. Re: How to add a  progress bar into a function which called itself recursively
            LearnIndesignScripting Level 1
            That is correct can you please tell how we can manage in this function as I am new
        var reportFilePath = myDoc.fullName.absoluteURI.replace(/\.indd$/i, ".txt");
        myTag(myDoc);
              function myTag(elm)
        try{
        for (var i = 0; i < elm.xmlElements.length; i++)
        try{
        XMLelementName=elm.xmlElements[i].markupTag.name.toString();
        if(XMLelementName=="span")
        if(elm.xmlElements[i].xmlAttributes.item("class").value == "name")
        myName = elm.xmlElements[i].parent.contents.replace(elm.xmlElements[i].contents, "");
        myName = myName.replace(" ", "");
        var endIP = elm.xmlElements[i].insertionPoints.firstItem();
        var endTF = endIP.parentTextFrames[0];
        var endCitationPage = endTF.parentPage;
        myFinalName = elm.xmlElements[i].contents +"," + myName;
        WriteToFile(myFinalName+"  "+endCitationPage.name,reportFilePath);
        elm.xmlElements[0].select();
        }catch(e){}
        myTag(elm.xmlElements[i]);
        }catch(e){}
                                                            function WriteToFile(text, reportFilePath) {
        file = new File(reportFilePath);
        file.encoding = "UTF-8";
        if (file.exists) {
        file.open("e");
        file.seek(0, 2);
        else {
        file.open("w");
        file.writeln(text);
        file.close();
