I'm going to use some very large numeric arrays for lookup tables and such. Can I substitute such an array with an ASCII85 encoded homogeneous number array? The arrays will only be used with the get operator, and will contain either 16 bit or 32 bit integers, or floating point numbers.
The PLRM states that HNAs are indistinguishable from literal arrays after the interpreter's scanner digested them. So I think the answer is yes. But you should try it out
with a small test proram.
This question is probably past it's use-by date by now, but: keep in mind that an HNA is just an alternative way of *encoding* an array in the PostScript stream. The PostScript scanner converts an HNA to a regular PostScript array internally; there's no savings in VM usage. (Just in case you were thinking this would be a more efficient way o storing an array.)
If you're looking to reduce VM use, you might be able to store your arrays as packedarrays; these take up about 70% as much VM as a regular array (and you can still express them in the PostScript stream as HNAs).
- John
John Deubert Acumen Training
john@acumentraining.com PostScript & PDF training & consulting
+1-949-248-1241 http://www.acumentraining.com
