4 Replies Latest reply on Nov 12, 2014 1:57 AM by Philip_ Wells
    I cannot install the 11.0.3 RoboHelp Patch.
    Philip_ Wells
      I cannot install the 11.0.3 RoboHelp Patch. I have manually downloaded it, unzipped it and then tried to install it. A message tells me I do not have Administrators rights even when I install using the 'Run as Administrator' option from the Windows right click menu. The update option is also grayed out on the Help menu in RoboHelp, so I can't use that option either.
        • 1. Re: I cannot install the 11.0.3 RoboHelp Patch.
          Hi there
          Sounds like it's time to get your IT staff involved. It's likely tied to the rights available when you log into Windows. Those are different rights than what you see when you run applications such as RoboHelp.
          Cheers... Rick
          • 2. Re: I cannot install the 11.0.3 RoboHelp Patch.
            Philip_ Wells Level 1
            Hi Rick,
            I have full administrators rights on the computer. I am also using the Run as Administrator option on the right click menu. The Adobe error message says updates have been suppressed by the administrator - which does look like a Windows message. However, prior to originally posting on the Adobe forum I did get the IT staff involved - they have verified that i do have the appropriate permissions.
            I suspect that the problem is actually within RoboHelp. Here's the Help menu.
            Although there is a valid update - 11.0.3. - the Updates option is grayed out. In other words there is a valid update to download, but RoboHelp does not recognise it.
            Cheers,
            Phil
            • 3. Re: I cannot install the 11.0.3 RoboHelp Patch.
              Mayank_M Adobe Employee
              Hi Phil,
              Please go to :
              1. C:\Program Files (x86)\CommonFiles\Adobe\AAMUpdaterInventory\1.0
              2. Copy “AdobeUpdaterAdminPrefs.dat” file to your desktop.
              3. Open it on a notepad from your desktop.
              4. change the value in Suppressed tag to be 0 from 1. It should as below
              5. <?xml
                    version="1.0" encoding="UTF-8" ?>
              6. <Preferences>
              7. <Suppressed>0</Suppressed>
              8. </Preferences>
              9. Save it and replace it back with the original file.
              10. Try to run the patch again.
              Regards,
              Mayank
              • 4. Re: I cannot install the 11.0.3 RoboHelp Patch.
                Thank you. This solved the problem - although in the meantime it got escalated up to a high level in my company (a major multinational) because of the security implications.
                Anyone else with this problem should note that these patches are not cumulative. There are currently three patches for RoboHelp 11. They have to be downloaded and installed in sequence.
