6 Replies Latest reply on Nov 6, 2014 5:42 PM by A.T. Romano
    I have a black border around my video and I would like it to be full screeen
    BruceKeenan Level 1
      I am running Premier Elements 10 on a PC and I am getting a black boarder around the video and I have rendered it multiple ways.   Is there a way to get it gone?  This is the link for youtube.  HCC 2014 video Final - YouTube
      Thank you
      Bruce
        • 1. Re: I have a black border around my video and I would like it to be full screeen
          A.T. Romano Level 7
          BruceKeenan
          Somewhere along the line from project preset to export settings there is a mismatch of settings.
          1. What did you set as the project preset in the new project dialog that met you when you opened that new project?
          If you did nothing, you probably have a NTSC DV Standard 4:3 or PAL DV Standard 4:3 project set up.
          2. What are the properties of the source media that you imported to the Timeline of this project?
          Video compression, audio compression, frame size, frame rate, interlaced or progressive, file extension, pixel aspect ratio?
          3. When your imports were on the Timeline, did they present in the Edit area monitor with black borders (top, bottom, right , left)?
          4. When you went to export that Timeline, please give me a specific example of your Share/ choice and settings (default or customized
          preset under the Advanced Button/Video Tab)?
          Right now I am guessing that you setup for a 4:3 project and exported as 16:9. But, let us see what your details indicate.
          Thank you.
          ATR
          Also, you may find the following YouTube Advanced Encoding Settings document of interest.
          https://support.google.com/youtube/answer/1722171?hl=en
          • 2. Re: I have a black border around my video and I would like it to be full screeen
            BruceKeenan Level 1
            Answers below in CAPS  and THANK YOU Bruce KeenanPresident, Himalayan Children's Charitieswww.hccnepal.org
            To: Bruce Keenan <bckeenan@yahoo.com>
            Sent: Thursday, November 6, 2014 5:04 PM
            Subject:  I have a black border around my video and I would like it to be full screeen
            created by A.T. Romano in Premiere Elements - View the full discussionBruceKeenan Somewhere along the line from project preset to export settings there is a mismatch of settings. 1. What did you set as the project preset in the new project dialog that met you when you opened that new project?If you did nothing, you probably have a NTSC DV Standard 4:3 or PAL DV Standard 4:3 project set up.  MIGHT BE THE PROBLEM 2. What are the properties of the source media that you imported to the Timeline of this project?Video compression, audio compression, frame size, frame rate, interlaced or progressive, file extension, pixel aspect ratio?  I AM USING MP4 VIDEOS SHOT IN 1920, 16:9 FORMAT.   3. When your imports were on the Timeline, did they present in the Edit area monitor with black borders (top, bottom, right , left)?  ONLY BORDERS TOP AND BOTTOM, NOT LEFT AND RIGHT 4. When you went to export that Timeline, please give me a specific example of your Share/ choice and settings (default or customizedpreset under the Advanced Button/Video Tab)?  I HAVE TRIED A F4V-HD 1080P PRESET WHICH GETS ME A MP4 OUT AND A NTSC DVD WIDESCREEN WHICH GETS ME A MPEG2 Right now I am guessing that you setup for a 4:3 project and exported as 16:9. But, let us see what your details indicate. Thank you. ATR Also, you may find the following YouTube Advanced Encoding Settings document of interest.https://support.google.com/youtube/answer/1722171?hl=en Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at https://forums.adobe.com/message/6906818#6906818 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:  To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.  Start a new discussion in Premiere Elements by email or at Adobe Community For more information about maintaining your forum email notifications please go to http://forums.adobe.com/thread/416458?tstart=0.
            • 3. Re: I have a black border around my video and I would like it to be full screeen
              A.T. Romano Level 7
              BruceKeenan
              Thank you for the reply with a lot of important details.
              With a 99.9999% certainty, I believe you issue is that
              a. you used 4:3 project settings for 16:9 source media
              b. when you imported that 16:9 source media you used it as is without scaling
              it to get rid of the black border at the top and bottom of the frame caused by the 16:9 source in
              a 4:3 project.
              Apparently when you opened the new project, you accepted the default which is NTSC DV Standard 4:3 instead
              of changing that to the project preset that would best match the properties of your source 16:9.
              For you to check out...
              a. Open a new project and, in the new project dialog, click on change settings, followed by
              changing the project preset to
              NTSC
              DSLR
              1080p
              DSLR 1080p30@29.97
              b. If you really want a F4V file HD, then
              Share
              Computer
              Adobe Flash Video
              with Presets = F4V - HD1080p (Flash 9 and Higher)
              If you want a MPEG2 file (SD), then
              Share
              Computer
              MPEGS
              with Presets = NTSC DVD Widescreen
              If you want a MPEG2 file (HD), then
              Share
              Computer
              MPEG2
              with Presets = HDTV 1080p 29.97 High Quality
              If you want to explore with an AVCHD.mp4 file (HD), then
              Share
              Computer
              AVCHD
              with Presets =  MP4 - H.264 1920 x 1080p30
              Lots to explore. And, there should be no black borders anywhere. If any questions or need
              clarification, please do not hesitate to ask.
              Thank you.
              ATR
              • 4. Re: I have a black border around my video and I would like it to be full screeen
                BruceKeenan Level 1
                Answers in CAPS.  But from playing with the file, it does not appear that I can get rid of the black border.   I would have to start again from scratch.    I tried a FV4 file format and a AVCHD.mp4 format and they both have black borders.   Any other suggestions on how to get rid of the border, or is it impossible at this point.
                Thanks Bruce KeenanPresident, Himalayan Children's Charitieswww.hccnepal.org
                Sent: Thursday, November 6, 2014 6:14 PM
                created by A.T. Romano in Premiere Elements - View the full discussionBruceKeenan Thank you for the reply with a lot of important details. With a 99.9999% certainty, I believe you issue is thata. you used 4:3 project settings for 16:9 source mediab. when you imported that 16:9 source media you used it as is without scalingit to get rid of the black border at the top and bottom of the frame caused by the 16:9 source ina 4:3 project. Apparently when you opened the new project, you accepted the default which is NTSC DV Standard 4:3 insteadof changing that to the project preset that would best match the properties of your source 16:9. For you to check out... a. Open a new project and, in the new project dialog, click on change settings, followed bychanging the project preset toNTSCDSLR1080pDSLR 1080p30@29.97
                I OPENED A NEW PROJECT AND THE STANDARD SET WAS NTSC-DV-STANDARD-48kHz WHICH IS MY PROBLEM AS YOU POINTED OUT.
                 b. If you really want a F4V file HD, thenShareComputerAdobe Flash Videowith Presets = F4V - HD1080p (Flash 9 and Higher) If you want a MPEG2 file (SD), thenShareComputerMPEGSwith Presets = NTSC DVD Widescreen If you want a MPEG2 file (HD), thenShareComputerMPEG2with Presets = HDTV 1080p 29.97 High Quality If you want to explore with an AVCHD.mp4 file (HD), thenShareComputerAVCHDwith Presets =  MP4 - H.264 1920 x 1080p30 Lots to explore. And, there should be no black borders anywhere. If any questions or needclarification, please do not hesitate to ask. Thank you. ATR Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at https://forums.adobe.com/message/6906984#6906984 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:  To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
                • 5. Re: I have a black border around my video and I would like it to be full screeen
                  A.T. Romano Level 7
                  BruceKeenan
                  Thanks for the reply.
                  I would have to go deeper into your situation to determine if we could edit the Notepad document of the saved closed project file
                  in order to correct the project preset issue. But, in the long run, it will probably save more time starting a new project with
                  the project preset suggested and begin anew.
                  Before you do that, you could do a mini test run to prove to yourself the benefits of starting over. With the mini test run completed
                  successfully, it might be incentive to start anew for the grand project.
                  The following is an idea of what we would need to go through if we wanted to try to correct the current project's condition.
                  http://www.atr935.blogspot.com/2013/11/pe10-changing-project-preset-without.html
                  We will be watching for your progress.
                  Thank you for the follow ups.
                  ATR
                  • 6. Re: I have a black border around my video and I would like it to be full screeen
                    BruceKeenan Level 1
                    AT
                    Thank you for the reply.  I am hosting an event where this video will be shown tomorrow, so unfortunately, there will not be time to do it over.   I am sure that I will have the correct setting to start when I create my next video, but for now, this will have to suffice.
                    Thank you again for your support. Bruce KeenanPresident, Himalayan Children's Charitieswww.hccnepal.org
                    Sent: Thursday, November 6, 2014 7:34 PM
                    created by A.T. Romano in Premiere Elements - View the full discussionBruceKeenan Thanks for the reply. I would have to go deeper into your situation to determine if we could edit the Notepad document of the saved closed project filein order to correct the project preset issue. But, in the long run, it will probably save more time starting a new project withthe project preset suggested and begin anew. Before you do that, you could do a mini test run to prove to yourself the benefits of starting over. With the mini test run completedsuccessfully, it might be incentive to start anew for the grand project. The following is an idea of what we would need to go through if we wanted to try to correct the current project's condition.http://www.atr935.blogspot.com/2013/11/pe10-changing-project-preset-without.html We will be watching for your progress. Thank you for the follow ups. ATR Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at https://forums.adobe.com/message/6907322#6907322 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:  To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
                    • 7. Re: I have a black border around my video and I would like it to be full screeen
                      A.T. Romano Level 7
                      BruceKeenan
                      Thanks for the follow up. Sorry that you did not post sooner on this.
                      You will do just fine presenting your students and their futures.
                      Best wishes
                      ATR
