4 Replies Latest reply on Nov 7, 2014 4:53 AM by BobLevine
    List Box in Forms
      I'm creating a PDFs form which has a list box. Is it possible to format the text within the list box to reflect the rest of the text in the document . Ie font style etc etc I can change the font size when creating the list box but there's no other formatting options.
        • 1. Re: List Box in Forms
          BobLevine MVP & Adobe Community Professional
          Not in InDesign. That has to be done in Acrobat.
          • 2. Re: List Box in Forms
            mghisted Level 1
            Many thanks. Can the document be created in indesign and then edited in Acrobat? Or do I have to do the whole thing in acrobat? Im not really an acrobat user...guessing I will need to learn.
            many thanks
            • 3. Re: List Box in Forms
              TᴀW Adobe Community Professional & MVP
              You can create the form in InDesign, and then format each form field in
              Acrobat. If you'll be going back and forth between InDesign and Acrobat
              (for corrections, etc.) you'll lose the formatting and have to redo it
              each time.
              If your form is a single page, and has up to 10 form fields, you can use
              the free version of FormMagic -- you create the form as usual in
              InDesign, but run FormMagic in InDesign to save a file containing the
              details of your form's formatting. Then, when you export the form to
              Acrobat, you go to the FormMagic entry at the bottom of the edit menu in
              Acrobat and run that command to restore the formatting to all your form
              • 4. Re: List Box in Forms
                Depends on the changes. You can make changes to the layout and then replace the page in Acrobat while retaining the form fields. Of course if things moved, you'll need to move the fields to match.
