1. Re: Finally Found Answer To My Color Mismatch Issues
Jacob Bugge Nov 7, 2014 1:58 AM (in response to JimGoshorn)Jim,
Thank you for sharing.
That was my first guess in the first post in the other thread:
No bright reds in my Illustrator
2. Re: Finally Found Answer To My Color Mismatch Issues
dougofakkad Nov 7, 2014 2:11 AM (in response to JimGoshorn)I wonder if there could be such a thing as a CMYK monitor. digital ink or something.
3. Re: Finally Found Answer To My Color Mismatch Issues
JimGoshorn Nov 7, 2014 4:39 PM (in response to Jacob Bugge)I don't understand the logic of the RGB space affecting the display though. Logic would say that no matter what RGB colorspace is set, in a CMYK document, Adobe would adjust the space to match CMYK automatically so the panels display correctly. Interestingly enough, Colormatch RGB which is supposed to be very close in gamut to CMYK, also dulls the color display to a small degree. I now have a CMYK setting using sRGB and an RGB setting using Prophoto to avoid the issue
Hoping that this post helps others out with something that is an undocumented gotcha.
