4 Replies Latest reply on Nov 10, 2014 12:46 AM by VeluVK
    Remove spaces from the empty cells
    VeluVK Level 1
      In most of tables there was an empty cells. In this cells there was white spaces and non breaking spaces are occurs. I need to delete all these spaces for all tables.
      Can i have any script.
      Regards,
      Velu
        • 1. Re: Remove spaces from the empty cells
          Jump_Over Level 5
          In UI - select a table or cell range and run Grep:
          find: ^\s+$
          change: <empty>
          script - run changeGrep() method with chosen target, i.e.
          app.activeDocument.stories.everyItem().tables.everyItem().changeGrep();
          Jarek
          • 2. Re: Remove spaces from the empty cells
            Sajeev Sridharan Level 4
            Try this,
            for (s=0; s<app.activeDocument.stories.length; s++)
                for (t=0; t<app.activeDocument.stories[s].tables.length; t++)
                    app.activeDocument.stories[s].tables[t].select();
                    var sel = app.activeDocument.selection[0];
                    if(sel instanceof Table)
                        var col = sel.columns;
                        for(var i=0;i<col.length;i++)
                            var cell = col[i].cells
                            for(var j=0;j<cell.length;j++)
                                if(cell[j].contents == " " || cell[j].contents == " ") //add your conditions here like double spaces, double non breaking space etc..
                                    cell[j].select();
                                    cell[j].texts[0].remove();
            Vandy
            • 3. Re: Remove spaces from the empty cells
              pixxxel schubser Level 5
              Sajeev Sridharan,
              I'm not an InDesign scripter, but IMHO your script is too complicated.
              Hi VeluVK,
              I'm with Jump_Over – Grep ist a good solution.
              Otherwise I think you can do something like this
              // RemoveSpacesFromEmptyCells.jsx
              // regards pixxxelschubser
              var cellTxt = app.documents.firstItem().stories.everyItem().tables.everyItem().cells.everyItem().texts.firstItem().getElements();
              for ( var i = 0; i < cellTxt.length; i++ ) {
                  cellTxt[i].contents = cellTxt[i].contents.replace(/^\s+$/,'');
              Have fun
              • 4. Re: Remove spaces from the empty cells
                VeluVK Level 1
                Thaks vandy,
                It working fine
                Regards,
                velu
                • 5. Re: Remove spaces from the empty cells
                  VeluVK Level 1
                  Hi pixxxel schubser,
                  It working fine.
                  Regards,
                  velu
