6 Replies Latest reply: Nov 8, 2014 8:09 PM by Jao vdL RSS
    ADVICE: Building a new system for 4K Lightroom Editing
    Picturequest Community Member
      Hi Gang,
      My PC is getting old. In the next few months I'd like to build a new system. Currently I run 1080p on a Samsung 52" display. I've seen how nice images look up close on 4K displays. And with 4K coming down in price i think that should be my goal.
      First, this needs to be somewhat on the economy side. Not a $1000 CPU.
      First,I know Nvidia released some updated video cards. Does Lightroom offload any processing to the GPU like PS? I was looking at the
      GeForce GTX 970 ACX 2.0 4GB GDDR5 256bit ($379)
      Of the new intel processors, what gives the best bang for the buck? Again, I can't afford the top of the line $1,000+ CPU. But i will stick with Intel.
      Obviously I need a good motherboard that can accept a lot of RAM.
      I was thinking of one of those PCI SSDs as a start up.
      Am I correct, that it is best not to have LIGHTROOM and the catalog on the Statup SSD? So I can have a second SSD just for the Catalog and previews?
      I think with Apples 5k computer, The PC market will get on board with 4K+ displays and video cards.
      And after using a 52" display for 4 years, no way can I go back to a tiny 27" display. Even if it has better color. Most likely will get a 60" 4K display.
      I know gamers complain about the refresh rate of current 4K displays, but for Lightroom should 30 or 60 hz refresh make a difference?
      This will be my main computer for the next 4 years or so.
      Thanks for your thoughts.
      Alex
        • 1. Re: ADVICE: Building a new system for 4K Lightroom Editing
          dj_paige Community Member
          Economy CPU?
          Big mistake. If you are going to run a 4K display, you need lots of CPU horsepower.
          At present, Lightroom does not use a GPU, so all rendering of your images must be done by the CPU, and for a 4K display, that means getting a powerful CPU.
          In this situation, the idea of "bang for the buck" I think ought to be replaced with the idea of getting the most powerful CPU you can afford. Yes, I would recommend that top of the line $1000 CPU, whatever that is ...
          • 2. Re: ADVICE: Building a new system for 4K Lightroom Editing
            Strange LR does not use the GPU (Mercury Engine). Maybe when 6.0 comes out. The small increase in clock speed from a midrange to the Extreme CPUs is not warranted unless you are a gamer. I would not over clock, so an unlocked CPU would be wasted $$. Now that Mac has a 5K display, and many androids have Quad HD displays. 4K will become the new standard. Makes a big difference looking at an image up close.
            • 3. Re: ADVICE: Building a new system for 4K Lightroom Editing
              Not strange at all, LR architecture is different than Photoshop, and the designed have stated that they get more speed this way than by using the GPU. I have no idea if Lightroom 6 will use the GPU or not.
              The small increase in clock speed from a midrange to the Extreme CPUs is not warranted unless you are a gamer or you are using Lightroom on a 4K monitor
              • 4. Re: ADVICE: Building a new system for 4K Lightroom Editing
                It just shows lack of knowledge, that you would equate the graphics intense nature of rendering a 3D game at its highest 100+ frames a second, overclocked and water cooled CPU, to the relatively light processing power needed to render a single RAWs development settings. Or even Exporting a 24 megapixel to a JPG or Tiff.  I'm pretty sure the ability to handle a 4K screen resolution vs. 1080p has more to do with the cores on a GPU than a CPU.
                • 5. Re: ADVICE: Building a new system for 4K Lightroom Editing
                  Jao vdL Community Member
                  Actually the raw processing pipeline is computationally surprisingly more complex than rendering 3D games. The reason it is not wholly done by ACR and Lightroom on the GPU is that there is very little speedup and even some speed loss under certain conditions according to the Adobe folks. The only raw converter that supposedly does raw rendering on the GPU is Apple's Aperture. It is no speed demon even on the highest end machines that Apple sells. On their Mac Pro which has dual video cards precisely to do GPU computation, Lightroom feels a lot faster than Aperture! GPUs are good at operations that can be done massively parallel and in low precision and that have few conditionals in them. 3D rendering is a typical example of that as is video effect rendering, fluid dynamics calculations, etc. For some reason, raw demosaicing and processing is not one of those. I don't believe you'll see GPU raw processing very soon especially since the camera megapixels keep going up with the same pace as GPUs get faster.
                  P.S. it is not true that Lightroom does not use the GPU. It just doesn't use it for the raw file processing. It does use it for displaying images, scaling images to the screen res, etc.
                  • 6. Re: ADVICE: Building a new system for 4K Lightroom Editing
                    Wow, my knowledge must be old. Apparently PhaseOne added OpenCL support in Capture One in v8. It's supposed to speed up raw rendering by quite a bit: Capture One Pro features Maybe I should check it out again.
