3 Replies Latest reply: Nov 8, 2014 1:07 PM by A.T. Romano RSS
    playback problems
    Kikkolo Community Member
      Everything was fine with my Project until I needed a new graphic board.
      I am able to open the Project, all the Content is in the timeline and I can start the playback, but
      there is no Video in the preview Monitor. There is just a freeze of the Moment where I started the playback.
      The Project and the Clips are HD Format (AVCHD).
      When I open a DV Standard Project I am able to Play the Clips.
      So what is the Problem with my Project? It did work with my old grapic board...
      Please help!
        • 1. Re: playback problems
          A.T. Romano Community Member
          Kikkolo
          What version of Premiere Elements are you using and on what computer operating system is it running?
          What is the video card/graphics card that your computer is now using?
          Please clarify
          a. Did you go from one card to another on the same computer operating system or did you go with 2 video cards/graphics cards instead of 1 on that same computer operating system? In any case, what did you go from and to?
          I get the uncomfortable sense that you are using Premiere Elements 10 and are now using a NVIDIA GeForce card?
          Hope that is not the case, but so far it is fitting the Premiere Elements 10/NIVIDIA GeForce issue profile.
          Looking forward to more details of your situation.
          Thank you.
          ATR
          • 2. Re: playback problems
            You are absolutely right. I am using Premiere Elements 10 and a NIVIDIA Geforce Card.
            I use Windows 7, 32 Bit System. It is a Medion PC I bought with a graphic Card included. With this Card everything was fine, but I was not able to identify the Card...
            So,  I should better use another Card? Which one?
            Thank you so much for your help so far!
            kikkolo
            • 3. Re: playback problems
              Kikkolo
              Please let me know the specific NVIDIA GeForce card video card/graphics card that your Windows XP 32 bit computer uses, and
              I will try to determine which driver version you need to roll back to in order to get your Premiere Elements 10 working for you.
              I can determine that from a NVIDIA link in the following
              ATR Premiere Elements Troubleshooting: PE10: NVIDIA Video Card Driver Roll Back
              The link in the link that I will use is the following
              NVIDIA Driver Downloads - Advanced Search
              I just need to plug your specific details into each of the fields.
              Typically the driver version roll back has had to go back as far as May 2013.
              Looking forward to your follow up.
              Thank you.
              ATR
