2 Replies Latest reply on Mar 22, 2007 7:26 PM by cgorak
    Problem with Captivate2 and IE7???
    cgorak Level 1
      My *.html file will not play when I publish from Captivate2 - I have the *.html and *.swf in the same directory just like I always have but the *.htm will not play - the *.swf plays but it is oversized and a bit blurry. I am using Windows XP and IE7 - anyone have any ideas? Thanks - Char Gorak (Grumpyswife)
        • 1. Re: Problem with Captivate2 and IE7???
          Hi cgorak
          Sounds like you are unaware there are additional files to ensure you copy to the server before a Captivate 2 presentation will actually work.
          MainMovie.SWF (MainMovie is your movie name and will vary)
          MainMovie_skin.SWF (MainMovie is your movie name and will vary)
          standard.js (likely the missing ingredient here - needed to make things work)
          MainMovie.HTM (The HTML file you steer your users to)
          So take another look and ensure you have all the files Captivate expects to find and you should be good to go.
          Cheers... Rick
          • 2. Re: Problem with Captivate2 and IE7???
            cgorak Level 1
            That was it - Thank you soooooo much. This is different than with Cap1 - I only had to post the two files with the first version. Thanks again! -Char Gorak
