This content has been marked as final.
Show 1 reply
1. Re: Importing from wordpress export..
Herbert2001 Nov 7, 2014 10:10 PM (in response to cepwin1)You might get better response if you posted this question on the Wordpress forums...
Having said that:
1) did you use the built-in Wordpress export under Tools in the WP backend?
2) to import the xml file, you must first install the wordpress importer plugin. Did you install it?
3) after installing the plugin, you must run the importer (WP should do this right after you installed the WP importer plugin), choose the file, and click on the button "Upload file and import".
So, is this the answer you were looking for?
