7 Replies Latest reply on Nov 8, 2014 8:16 PM by Andrew Yoole
    After Effects PNG Sequence Error Help Please
    matthew112343
      When I try to render a png sequence I got the following errors
      After effects warning: Could not create file <file path> Access was denie
      Another message box saying
      AEGP plugin PNGIO Support: Unable to create PNGIO
      (5027::12)
      After Effects error cannot close a closed file
      (3::5)
      It renders a few frames and then it crashes with these errors. Please help THANKS
        • 1. Re: After Effects PNG Sequence Error Help Please
          Without exact system info and other details like what version of AE you actually use plus exact render settings nobody can tell you much. There is any nomber of PNG issues, especially under different versions of Mac OSX and different versions of AE due to Apple changing stuff in Quicktime, but without more detailed info nobody can advise.
          Mylenium
          • 2. Re: After Effects PNG Sequence Error Help Please
            matthew112343 Level 1
            Im running windows 7 and After Effects CC.
            • 3. Re: After Effects PNG Sequence Error Help Please
              Here is my log
              Adobe After Effects v12.0 (Windows 64) render log for project “Untitled Project.aep”
              Rendering started on 11/8/2014 at 9:34:58 AM
                11/8/2014 9:34:58 AM: Starting composition “cinematicsPre 2”.
                Render Settings: Best Settings
                Quality: Best
                Resolution: Full
                Size: 1702 x 953
                Proxy Use: Use No Proxies
                Effects: Current Settings
                Disk Cache: Read Only
                Color Depth: Current Settings
                Frame Blending: On for Checked Layers
                Field Render: Off
                Pulldown: Off
                Motion Blur: On for Checked Layers
                Solos: Current Settings
                Time Span: Work Area
                Start: 0:00:04:10
                End: 0:00:25:27
                Duration: 0:00:21:19
                Frame Rate: 30.00
                Guide Layers: All Off
                Skip Existing Files: Off
                Output Module:Lossless
                Output To:C:\Users\Matthew\Desktop\Youtube   Stuff\ObeyRC\Sequence\1\cinematicsPre 2_[#####].png
                Format: PNG
                Output Info: -
                Start Frame: 130
                Output Audio: -
                Channels: RGB
                Depth: Millions of Colors
                Color: Premultiplied
                Resize: -
                Crop: -
                Final Size: 1702 x 953
                Profile:  -
                Post-Render Action: None
                0:00:04:10 (1): 3 Seconds
                0:00:04:11 (2): 1 Seconds
                0:00:04:12 (3): 1 Seconds
                0:00:04:13 (4): 1 Seconds
                0:00:04:14 (5): 1 Seconds
                0:00:04:15 (6): 1 Seconds
                0:00:04:16 (7): 1 Seconds
                0:00:04:17 (8): 1 Seconds
                0:00:04:18 (9): 1 Seconds
                0:00:04:19 (10): 1 Seconds
                0:00:04:20 (11): 1 Seconds
                0:00:04:21 (12): 1 Seconds
                0:00:04:22 (13): 1 Seconds
                0:00:04:23 (14): 1 Seconds
                0:00:04:24 (15): 1 Seconds
                0:00:04:25 (16): 1 Seconds
                0:00:04:26 (17): 0 Seconds
                0:00:04:27 (18): 1 Seconds
                0:00:04:28 (19): 1 Seconds
                0:00:04:29 (20): 1 Seconds
                0:00:05:00 (21): 1 Seconds
                0:00:05:01 (22): 1 Seconds
                0:00:05:02 (23): 1 Seconds
                0:00:05:03 (24): 0 Seconds
              After Effects warning: Could not create the file 'C:\Users\Matthew\Desktop\Youtube   Stuff\ObeyRC\Sequence\1\cinematicsPre 2_00154.png'. Access was denied.
              AEGP Plugin PNGIO Support: Unable to create PNGIO. (5027  ::  12)
              After Effects error: cannot close a closed file. (3  ::  5)
                11/8/2014 9:35:23 AM: Finished composition “cinematicsPre 2”.
                Total Time Elapsed: 25 Seconds
              Log closed on 11/8/2014 at 9:35:23 AM
              • 4. Re: After Effects PNG Sequence Error Help Please
                Well, let's ask the simple question: Do you actually have enough disk space, not just in the target folder but also in your temp and cache folders?
                Mylenium
                • 5. Re: After Effects PNG Sequence Error Help Please
                  Yes Ive cleared by temp and cache folders. I have enough RAM and disk space as well.
                  • 6. Re: After Effects PNG Sequence Error Help Please
                    brad.magnus Level 1
                    I'm having the same problem! Hope I can get this cleared up by Monday.
                    • 7. Re: After Effects PNG Sequence Error Help Please
                      Andrew Yoole MVP & Adobe Community Professional
                      Can you render the same composition to a different format just to test it?  Like a JPEG, PSD  or TIF sequence?
