1 Reply Latest reply on Nov 19, 2014 7:31 AM by Bruce Bullis
    Is there any way to export still frame using ExtendScript?
    iiss
      Hello. I need to do the same that "Export Frame" button does but via JavaScript (just export current frame from the sequence as .tiff). I did not find any method in DOM for this. Is it possible?
        • 1. Re: Is there any way to export still frame using ExtendScript?
          Bruce Bullis Adobe Employee
          No*.
          * There isn't one call; you would need to create an output preset (.epr file) that renders the current sequence to a still format, and set the work area of the sequence to include only the frame(s) you want. Once you have this, you can use app.encoder.encodeSequence() to generate your still frame.
          Feel free to write me directly with related questions: b b b at adobe dot com
