1. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
Captiv8r Nov 8, 2014 11:01 AM (in response to kberryman_mlink)Hi there
Something like this is impossible to provide an "it might be this" troubleshooting shot by just looking at a static image. Heck, even if you provided a link that opened the final result we would have the same issue. Likely, only by having access to the project file and seeing it first hand would we be able to possibly try and suggest something.
I'm doubtful it would help, but on the outside chance it may, perhaps share a screen capture of your Timeline for the slide as well as the properties for the Smart Shape.
Cheers... Rick
2. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
kberryman_mlink Nov 8, 2014 11:30 AM (in response to Captiv8r)I can definitely supply of those things...
Course: http://mlinkreview.com/Mosaic/test/
Files: http://mlinkreview.com/Mosaic/test/EDGE_test.zip
3. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
Captiv8r Nov 8, 2014 2:50 PM (in response to kberryman_mlink)Hello again
Thanks for the links. I think I sorted it.
Click the slide in question and look at the properties. You have the option "Master Slide Objects on Top" enabled. Something about that is preventing the shape from sensing the rollover.
Click to clear that option and the mouseover should then work.
Cheers... Rick
4. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
kberryman_mlink Nov 8, 2014 2:56 PM (in response to kberryman_mlink)So the rollovers will not work if the Master Slide Objects On Top feature is selected? That seems like a bit of a limitation. I'd already discovered that the master slide objects on top kill drag and drops, but rollovers too?
5. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
Captiv8r Nov 8, 2014 3:20 PM (in response to kberryman_mlink)Here's the deal
Looks like you had a couple of images or whatever that sat on top of the master slides as images. And you also had the "Master Slide Objects on Top" selected. So my guess is that it pushed those objects to the top of the stack. And that causes the problem, because now an image is sitting between the Smart Shape and it doesn't detect the mouseover. The good news is that the button still works. And the bad news is that it causes an issue with the mouseovers.
I suppose one solution would involve configuring that image as just the background for that content master slide, Either that, or just turn off the option to have master slide stuff on top for that slide.
Cheers... Rick
6. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
Captiv8r Nov 8, 2014 3:41 PM (in response to Captiv8r)Curiosity question here
Where did you get the cool Scrabble stuff?
Cheers... Rick
7. Re: Smart shape button rollover state not activating. No state change; no hand cursor on rollover.
kberryman_mlink Nov 8, 2014 3:57 PM (in response to kberryman_mlink)I was trying to get around having to bring the border into every slide since we wanted most of the items to be behind it. My layers are out of control as it is, haha. I guess I can just put my backgrounds in the masters instead.
The scrabble stuff was designed by someone here in my office.
