3 Replies Latest reply on Nov 10, 2014 9:21 AM by syswizardx
    Document-level Javascript as Object
    syswizardx Level 1
      I created a document level script called Utility.
      I want to create methods within this script rather than coding each one separately.
      function Utility()
      this.getFormattedDateOnly=function(pDate) {
        if (typeof pDate == "undefined") {
          pDate = new Date();
        var retval = util.printd("m/dd/yyyy",pDate);
        return retval;
      this.getFldsOnPagenum = function(pPageNum, pDoc) {
        /* returns an array of the form fields who are on or start on a page */
        /* zero based return ; however pPageNum is 1 thru numPages, not 0 -> numPages-1 */
        var currPage;
        var currFld;
        var cnt = -1;
        var ARflds = [];
      CPR("# flds=" + pDoc.numFields+" Type of pDoc:"+ (typeof pDoc));
        for (var i = 0; i < pDoc.numFields; i++) {
          currFld = pDoc.getNthFieldName(i);
          if (typeof currFld.page == "number") {
      CPR("page="+(1*currFld.page+1));
            if ((1*currFld.page+1) == pPageNum) {
              cnt++;
              ARflds.length = cnt + 1;
              ARflds[cnt] = currFld;
      CPR("\n cnt="+cnt);
          } else if ((1*currFld.page[0]+1) == pPageNum) {
            cnt++;
        return ARflds;
      var MyUtil = new Utility();
      This is all working fine with the following exceptions:
      1) the methods are not being registered in the Javascript hierarchy listing.
      That's annoying.
      2) "This" is not recognized at the document level....I must pass it as a parameter (pDoc).
      I thought that was strange...I could see it if were at the folder level.
      It appears the document object is out-of-scope !!
      3) currFld = pDoc.getNthFieldName(i);
      The above is failing....sending back a "currFld is undefined" error.
      I don't see the problem....very strange IMHO.
      When I call the getNthFieldName function from the console....no problem.
      What am I doing wrong in the definition here ?
      It appears that what I did has Acrobat functions and document properties out-of-scope.
        • 1. Re: Document-level Javascript as Object
          1) I never really use it, but it's possible it's just a list of the top-level methods, not nested ones.
          2) Correct. If you nest methods then you need to pass a reference to the document object. The "this" object will not always point to it.
          3) This method returns the name of a field, not a Field object.
          • 2. Re: Document-level Javascript as Object
            The JavaScript API document gives the definition of "this" in various contexts. In any context not listed it is undefined - DO NOT USE IT. "this" is not a variable to be inherited.
            • 3. Re: Document-level Javascript as Object
              syswizardx Level 1
              I think this would work if you could make the document object a member of the Object being created.
              To do that, a constructor needs to be invoked so that it can instantiate a public property of the Object.
              var MyUtil = new Utility(this);
              inside of Utility I would have:
              this.oPDFdoc =  this;
              thereby transferring a reference to the entire PDF document to my Object.
              Getting this to work would eliminate the need for all of the document-level javascript references.
