1 Reply Latest reply on Nov 8, 2014 6:56 PM by Bob Currier
    Render PNG Sequence Issue
    matthew112343
      Adobe After Effects v12.0 (Windows 64) render log for project “Untitled Project.aep”
      Rendering started on 11/8/2014 at 1:37:46 PM
        11/8/2014 1:37:46 PM: Starting composition “cinematicsPre 4”.
        Render Settings: Best Settings
        Quality: Best
        Resolution: Full
        Size: 1920 x 1082
        Proxy Use: Use No Proxies
        Effects: Current Settings
        Disk Cache: Read Only
        Color Depth: Current Settings
        Frame Blending: On for Checked Layers
        Field Render: Off
        Pulldown: Off
        Motion Blur: On for Checked Layers
        Solos: Current Settings
        Time Span: Work Area
        Start: 0:00:04:10
        End: 0:00:25:27
        Duration: 0:00:21:19
        Frame Rate: 30.00
        Guide Layers: All Off
        Skip Existing Files: Off
        Output Module:Lossless
        Output To:C:\Users\Matthew\Desktop\Youtube   Stuff\ObeyRC\Sequence\1\cinematicsPre 4_[#####].png
        Format: PNG
        Output Info: -
        Start Frame: 130
        Output Audio: -
        Channels: RGB
        Depth: Millions of Colors
        Color: Premultiplied
        Resize: -
        Crop: -
        Final Size: 1920 x 1082
        Profile:  -
        Post-Render Action: None
        0:00:04:10 (1): 3 Seconds
        0:00:04:11 (2): 1 Seconds
        0:00:04:12 (3): 1 Seconds
        0:00:04:13 (4): 1 Seconds
        0:00:04:14 (5): 2 Seconds
        0:00:04:15 (6): 1 Seconds
        0:00:04:16 (7): 1 Seconds
      After Effects warning: Could not create the file 'C:\Users\Matthew\Desktop\Youtube   Stuff\ObeyRC\Sequence\1\cinematicsPre 4_00137.png'. Access was denied.
      AEGP Plugin PNGIO Support: Unable to create PNGIO. (5027  ::  12)
      After Effects error: cannot close a closed file. (3  ::  5)
        11/8/2014 1:37:57 PM: Finished composition “cinematicsPre 4”.
        Total Time Elapsed: 10 Seconds
      Log closed on 11/8/2014 at 1:37:57 PM
      Ive delete temp and chache files as well as cleared RAM and it still doesnt work.
        • 1. Re: Render PNG Sequence Issue
          Bob Currier Level 3
          Seems to me the important line is:
          That would make me want to check out permissions to be certain that you have write access to that location.
