1. Re: impossible make a selection in Photoshop CC 2014 with 4mb of RAM
gener7 Nov 8, 2014 12:35 PM (in response to Valter Daghetti)CC 2014 has twice the ram requirements of CC. While 2 GB is minimum, 8 GB is recommended.
You will have to upgrade your system or go back to CC.
System requirements | Photoshop
Gene
2. Re: impossible make a selection in Photoshop CC 2014 with 4mb of RAM
Mougaard Nov 8, 2014 12:39 PM (in response to Valter Daghetti)Check if there is other appllications open .. something is eating your ram.
3. Re: impossible make a selection in Photoshop CC 2014 with 4mb of RAM
gener7 Nov 8, 2014 12:53 PM (in response to Mougaard)That is a good point. In Photoshop you can assign ram to it under Edit > Preferences > Performance.
The idea range for 32 bit systems is 1790-2343 MB. so you can check to see if you can assign more.
4. Re: impossible make a selection in Photoshop CC 2014 with 4mb of RAM
Valter Daghetti Nov 8, 2014 2:53 PM (in response to Valter Daghetti)Well Thanks for answer, I have to say that I not realize that the picture was 220mb. this was the main problem, then in Edit > Preferences > Performance Photoshop show only like max available 1599mb
while installed there is 4 gb. I planned of install more memory soon. My old PC is an HP XW4600
Thanks you
Valter
5. Re: impossible make a selection in Photoshop CC 2014 with 4mb of RAM
gener7 Nov 8, 2014 3:02 PM (in response to Valter Daghetti)One thing to note. If your OS is Windows 7-32 bit, you will have to install Windows 7 64-bit in order to address memory over 4 GB and reinstall your apps. Photoshop will install a 64 bit version that can access the extra ram.
Gene
