3 Replies Latest reply on Nov 9, 2014 1:14 AM by Mylenium
    After Effects render error PNG sequence
    brad.magnus Level 1
      What does that mean? The crazy part is that I've rendered the same png sequence 1 time before successfully, and now I can't make Ae more Media Encoder render the sequence... Any suggestions?
      Error Text
      "AEGP Plugin PNGIO Support: PNGIO library error: bad adaptive filter value
      ( 5027 :: 12 )"
        • 1. Re: After Effects render error PNG sequence
          brad.magnus Level 1
          Maybe I should also say, I'm on Windows 7. Newest version of Ae CC 2014. The sequence is a pre-rendered composite of a 3D tablet spinning around. Only other stuff going on is some text and graphics animations.
          • 2. Re: After Effects render error PNG sequence
            brad.magnus Level 1
            Also here's the render log file:
            Adobe After Effects v13.1.1 (Windows 64) render log for project “HP ElitePad Video 06 alt version.aep”
            Rendering started on 11/8/2014 at 9:11:56 PM
              11/8/2014 9:11:56 PM: Starting composition “Main”.
              Render Settings: Best Settings
              Quality: Best
              Resolution: Full
              Size: 1920 x 1080
              Proxy Use: Use No Proxies
              Effects: Current Settings
              Disk Cache: Read Only
              Color Depth: Current Settings
              Frame Blending: On for Checked Layers
              Field Render: Off
              Pulldown: Off
              Motion Blur: On for Checked Layers
              Solos: Current Settings
              Time Span: Work Area
              Start: 0:00:00:00
              End: 0:02:07:15
              Duration: 0:02:07:16
              Frame Rate: 30.00 (comp)
              Guide Layers: All Off
              Skip Existing Files: Off
              Output Module: Quicktime h264 70
              Output To: F:\HP-ElitePad-Final-BPS-Q4-Mobility-alt.mov
              Format: QuickTime
              Output Info: H.264
              Output Info:
            Spatial Quality = 70
              Include: Project Link
              Output Audio: 48.000 kHz / 16 bit / Stereo (if comp has audio)
              Channels: RGB
              Depth: Millions of Colors
              Color: Premultiplied
              Resize: -
              Crop: -
              Final Size: 1920 x 1080
              Profile:  -
              Post-Render Action: None
            AEGP Plugin PNGIO Support: PNGIO library error: bad adaptive filter value (5027  ::  12)
              11/8/2014 9:12:13 PM: Finished composition “Main”.
            Total Time Elapsed: 16 Seconds
            Log closed on 11/8/2014 at 9:12:13 PM
            Cleared my disk cache and for sure have the disk space.
            • 3. Re: After Effects render error PNG sequence
              No idea, but in light of the plethora of PNG errors in relation to AE CC 2014.1 I'd say it's completely busted and you need to convert your source files to another format...
              Mylenium
