3 Replies Latest reply on Nov 10, 2014 2:48 PM by pixxxel schubser
    How do you recursively loop through sublayers and groups?
    iamwickedtall Level 1
      I've been fairly successful looping through an AI file, and was able to loop through layers and pull text Layers, to a specified layer. Problem being, that I also want to capture anything that's nested in groups, and depending on which way I put the try statements, it will only catch parts of the editorial in my file. The problem occurs within the traverseSubs function, I had both groupItems and layers in one loop, but it wasn't fully going through anything, so I set 2 different variables to loop through.
      actDoc = app.activeDocument;
      textLayerName = "Live Editorial"
      layLen = actDoc.layers.length;
      function catchText(grabTextFrom,whereTo) {
          try{textCatchLayer = actDoc.layers.getByName(whereTo)}
          catch(e){
              var textCatchLayer = actDoc.layers.add();
              textCatchLayer.name = textLayerName;
              textCatchLayer.printable = false;
              textCatchLayer.zOrder(ZOrderMethod.BRINGTOFRONT);
          var tF = grabTextFrom.textFrames
          var tFL = tF.length;
          for ( i = 0; i < tFL; i++) {
             tF[i].duplicate(textCatchLayer, ElementPlacement.PLACEATEND);
      function traverseSubs(current) {
              catchText(current,textLayerName);
              for ( h = 0; h < current.groupItems.length; h++) {
                  try{if(current.groupItems.length > 0) traverseSubs(current.groupItems[h])}
                  catch(e) {$.write(e)}
              for ( i = 0; i < current.layers.length; i++) {
                  try{ if(current.layers.length > 0) traverseSubs(current.layers[h])}
      for (j = 0; j < layLen; j++){
              curLay = actDoc.layers[j];
              if(curLay.name == textLayerName) continue;
              traverseSubs(curLay);
      I also tried the below:
      tF = app.activeDocument.textFrames
      tFL = tF.length
        for(i=0;i<tFL;i++){
              tF[i].duplicate(app.activeDocument.layers.getByName("Live Editorial "), ElementPlacement.PLACEATEND);
      But it only grabbed the same Text 5 times.
