7 Replies Latest reply on Nov 11, 2014 2:50 PM by j_woody Branched from an earlier discussion.
    Re: Adobe Flash Player 15.0 r0 Has Stopped Working
    j_woody
      Thanks for your assistance  ... I will try any good suggestions you have. Please note the following:
      1. I really don't understand the previous information provided by "samclean"  ..... I did not submit an error report that generated those diagnosis.
      2. I get the same flash error when using Internet Explorer, so I'm not convinced that this is Firefox related.  I'm thinking that it's more likely an issue between Vista and Flash.
      Thanks again for any help you can provide.
        • 1. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
          jeromiec83223024 Adobe Employee
          I've branched this to a new discussion, since the issue you're experiencing sounds like it's unrelated to the thread you posted in.
          Let's start over with some basic information about the problem you're seeing:
          Read Before Posting: How To Get A Useful Answer To Your Question
          • 2. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
            j_woody Level 1
            Here's the original problem again  .....
            Looking for a solution to this problem that started several weeks ago, after a recent Windows update and / or Flash Player update.  I'm having this problem on my HP laptop that runs Vista (32 bit).  I normally use Firefox, but the same thing happens in Internet Explorer. Anytime I attempt to run a video, I get this error message  ... "Adobe Flash Player 15.0 r0 Has Stopped Working ... a problem caused the program to stop working.  Windows will close the program  .... "
            I have tried reinstalling the latest Flash Player version several times, and I have done the "CLEAN INSTALL" as suggested on this site.  But, so far, nothing has resolved this problem.
            • 3. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
              Please work through the following troubleshooting guide:
              Video playback issues
              If you're stil stuck, give me a rundown of what you did and the results, as well as the output of dxdiag.
              • 4. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
                j_woody Level 1
                I am able to play both videos in the link you sent, but I am still having a problems with most other videos.   See the below screen shots:
                I tried disabling hardware acceleration, but there was no change to the problem.   Below is the output from the diagnostics tool:
                System Information
                Time of this report: 11/11/2014, 12:32:37
                       Machine name: JRW_HP_LAPTOP
                   Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.130707-1535)
                           Language: English (Regional Setting: English)
                System Manufacturer: Hewlett-Packard
                       System Model: HP Pavilion dv3 Notebook PC
                               BIOS: Default System BIOS
                          Processor: Pentium(R) Dual-Core CPU       T4200  @ 2.00GHz (2 CPUs), ~2.0GHz
                             Memory: 3002MB RAM
                          Page File: 1933MB used, 4277MB available
                        Windows Dir: C:\Windows
                    DirectX Version: DirectX 11
                DX Setup Parameters: Not found
                     DxDiag Version: 7.00.6002.18107 32bit Unicode
                DxDiag Notes
                      Display Tab 1: No problems found.
                        Sound Tab 1: No problems found.
                        Sound Tab 2: No problems found.
                          Input Tab: No problems found.
                DirectX Debug Levels
                Direct3D:    0/4 (retail)
                DirectDraw:  0/4 (retail)
                DirectInput: 0/5 (retail)
                DirectMusic: 0/5 (retail)
                DirectPlay:  0/9 (retail)
                DirectSound: 0/5 (retail)
                DirectShow:  0/6 (retail)
                Display Devices
                        Card name: Mobile Intel(R) 4 Series Express Chipset Family
                     Manufacturer: Intel Corporation
                        Chip type: Mobile Intel(R) 4 Series Express Chipset Family
                         DAC type: Internal
                       Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_306D103C&REV_07
                   Display Memory: 1309 MB
                Dedicated Memory: 64 MB
                    Shared Memory: 1245 MB
                     Current Mode: 1366 x 768 (32 bit) (59Hz)
                          Monitor: Generic PnP Monitor
                      Driver Name: igdumdx32.dll,igd10umd32.dll
                   Driver Version: 7.15.0010.1591 (English)
                      DDI Version: 10
                   BGRA Supported: Yes
                Driver Attributes: Final Retail
                Driver Date/Size: 10/28/2008 02:25:44, 536576 bytes
                      WHQL Logo'd: n/a
                  WHQL Date Stamp: n/a
                Device Identifier: {D7B78E66-6902-11CF-BB75-6710A7C2CA35}
                        Vendor ID: 0x8086
                        Device ID: 0x2A42
                        SubSys ID: 0x306D103C
                      Revision ID: 0x0007
                      Revision ID: 0x0007
                      Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
                Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     DDraw Status: Enabled
                       D3D Status: Enabled
                       AGP Status: Enabled
                Sound Devices
                            Description: Speakers and Headphones (IDT High Definition Audio CODEC)
                Default Sound Playback: Yes
                Default Voice Playback: Yes
                            Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_7608&SUBSYS_103C306E&REV_1002
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            Driver Name: stwrt.sys
                         Driver Version: 6.10.6146.0000 (English)
                            WHQL Logo'd: n/a
                          Date and Size: 1/28/2009 07:16:04, 394240 bytes
                            Other Files:
                        Driver Provider: IDT
                         HW Accel Level: Basic
                              Cap Flags: 0x0
                    Min/Max Sample Rate: 0, 0
                Static/Strm HW Mix Bufs: 0, 0
                Static/Strm HW 3D Bufs: 0, 0
                              HW Memory: 0
                       Voice Management: No
                EAX(tm) 2.0 Listen/Src: No, No
                   I3DL2(tm) Listen/Src: No, No
                Sensaura(tm) ZoomFX(tm): No
                            Description: Independent Headphones (IDT High Definition Audio CODEC)
                Default Sound Playback: No
                Default Voice Playback: No
                        Manufacturer ID: 1
                             Product ID: 100
                                   Type: WDM
                            WHQL Logo'd: n/a
                            Other Files:
                              Cap Flags: 0x0
                              HW Memory: 0
                Sound Capture Devices
                            Description: Integrated Microphone Array (IDT High Definition Audio CODEC)
                  Default Sound Capture: Yes
                  Default Voice Capture: Yes
                              Cap Flags: 0x0
                           Format Flags: 0x0
                            Description: Stereo Mix (IDT High Definition Audio CODEC)
                  Default Sound Capture: No
                  Default Voice Capture: No
                              Cap Flags: 0x0
                           Format Flags: 0x0
                            Description: External Mic (IDT High Definition Audio CODEC)
                              Cap Flags: 0x0
                           Format Flags: 0x0
                DirectInput Devices
                      Device Name: Mouse
                         Attached: 1
                    Controller ID: n/a
                Vendor/Product ID: n/a
                        FF Driver: n/a
                      Device Name: Keyboard
                         Attached: 1
                    Controller ID: n/a
                        FF Driver: n/a
                      Device Name: Microsoft eHome Infrared Transceiver
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0x045E, 0x006D
                        FF Driver: n/a
                         Attached: 1
                    Controller ID: 0x0
                        FF Driver: n/a
                         Attached: 1
                    Controller ID: 0x0
                        FF Driver: n/a
                         Attached: 1
                    Controller ID: 0x0
                        FF Driver: n/a
                      Device Name: Bluetooth Remote Control HID Device
                         Attached: 1
                    Controller ID: 0x0
                Vendor/Product ID: 0xFFFE, 0xFFFE
                        FF Driver: n/a
                Poll w/ Interrupt: No
                USB Devices
                + USB Root Hub
                | Vendor/Product ID: 0x8086, 0x2934
                | Matching Device ID: usb\root_hub
                | Service: usbhub
                | Driver: usbhub.sys, 6/28/2013 20:07:15, 197632 bytes
                | Driver: usbd.sys, 6/28/2013 20:06:53, 6016 bytes
                Gameport Devices
                PS/2 Devices
                + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with HP QLB
                | Matching Device ID: *pnp0303
                | Upper Filters: HpqKbFiltr
                | Service: i8042prt
                | Driver: HpqKbFiltr.sys, 6/18/2007 18:12:04, 16768 bytes
                | Driver: wdfcoinstaller01005.dll, 11/2/2006 08:09:50, 1419232 bytes
                | Driver: i8042prt.sys, 1/20/2008 20:23:20, 54784 bytes
                | Driver: kbdclass.sys, 1/20/2008 20:23:23, 35384 bytes
                + Microsoft eHome Remote Control Keyboard keys
                | Matching Device ID: hid\irdevice&col05
                | Service: kbdhid
                | Driver: kbdhid.sys, 4/10/2009 22:38:40, 17408 bytes
                + Microsoft eHome MCIR Keyboard
                | Matching Device ID: hid\irdevice&col06
                | Service: kbdhid
                + Microsoft eHome MCIR 109 Keyboard
                | Matching Device ID: hid\irdevice&col07
                | Service: kbdhid
                | Driver: kbd106.dll, 1/20/2008 20:23:23, 6656 bytes
                + Terminal Server Keyboard Driver
                | Matching Device ID: root\rdp_kbd
                | Upper Filters: kbdclass
                | Service: TermDD
                + Synaptics PS/2 Port TouchPad
                | Matching Device ID: *syn1e07
                | Upper Filters: SynTP
                | Service: i8042prt
                + HID-compliant mouse
                | Matching Device ID: hid_device_system_mouse
                | Service: mouhid
                | Driver: mouhid.sys, 1/20/2008 20:23:20, 15872 bytes
                | Driver: mouclass.sys, 1/20/2008 20:23:20, 34360 bytes
                + Logitech USB Wheel Mouse
                | Vendor/Product ID: 0x046D, 0xC00E
                | Matching Device ID: hid\vid_046d&pid_c00e
                | Service: mouhid
                + Terminal Server Mouse Driver
                | Matching Device ID: root\rdp_mou
                | Upper Filters: mouclass
                | Service: TermDD
                | Driver: termdd.sys, 4/11/2009 00:32:52, 53224 bytes
                | Driver: sermouse.sys, 1/20/2008 20:23:20, 19968 bytes
                Disk & DVD/CD-ROM Drives
                      Drive: C:
                Free Space: 130.9 GB
                Total Space: 292.8 GB
                File System: NTFS
                      Model: SAMSUNG HM320JI ATA Device
                      Drive: D:
                Free Space: 2.0 GB
                Total Space: 12.5 GB
                File System: NTFS
                      Drive: E:
                      Model: Optiarc DVD RW AD-7581S ATA Device
                     Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/10/2009 22:39:17, 67072 bytes
                System Devices
                     Name: Intel(R) WiFi Link 5100 AGN
                Device ID: PCI\VEN_8086&DEV_4237&SUBSYS_12118086&REV_00\4&23507F69&0&00E2
                   Driver: n/a
                     Name: Mobile Intel(R) 4 Series Express Chipset Family
                Device ID: PCI\VEN_8086&DEV_2A43&SUBSYS_306D103C&REV_07\3&E89B380&0&11
                   Driver: n/a
                Device ID: PCI\VEN_8086&DEV_2A42&SUBSYS_306D103C&REV_07\3&E89B380&0&10
                   Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 7.15.0010.1591 (English), 10/28/2008 02:29:36, 2476544 bytes
                   Driver: C:\Windows\system32\igdumd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:29:40, 3411968 bytes
                   Driver: C:\Windows\system32\igkrng500.bin, 10/28/2008 02:28:36, 2026604 bytes
                   Driver: C:\Windows\system32\igcompkrng500.bin, 10/28/2008 02:28:36, 445796 bytes
                   Driver: C:\Windows\system32\igfcg550.bin, 10/28/2008 02:28:36, 147172 bytes
                   Driver: C:\Windows\system32\iglhxs32.vp, 10/28/2008 03:06:00, 36080 bytes
                   Driver: C:\Windows\system32\iglhxo32.vp, 10/28/2008 01:58:40, 2096 bytes
                   Driver: C:\Windows\system32\iglhxc32.vp, 10/28/2008 01:58:40, 2096 bytes
                   Driver: C:\Windows\system32\hccutils.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:28, 106496 bytes
                   Driver: C:\Windows\system32\igfxsrvc.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:50, 52224 bytes
                   Driver: C:\Windows\system32\igfxsrvc.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:44, 256536 bytes
                   Driver: C:\Windows\system32\igfxpph.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:08, 217088 bytes
                   Driver: C:\Windows\system32\igfxcpl.cpl, 7.14.0010.1591 (English), 10/28/2008 02:05:00, 126976 bytes
                   Driver: C:\Windows\system32\igfxcfg.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:36, 670232 bytes
                   Driver: C:\Windows\system32\igfxdev.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:24, 221184 bytes
                   Driver: C:\Windows\system32\igfxdo.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:36, 135168 bytes
                   Driver: C:\Windows\system32\igfxtray.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:46, 150040 bytes
                   Driver: C:\Windows\system32\hkcmd.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:34, 178712 bytes
                   Driver: C:\Windows\system32\igfxress.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:12, 5672960 bytes
                   Driver: C:\Windows\system32\igfxpers.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:42, 154136 bytes
                   Driver: C:\Windows\system32\igfxTMM.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:32, 258048 bytes
                   Driver: C:\Windows\system32\igfxext.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:38, 178712 bytes
                   Driver: C:\Windows\system32\igfxexps.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:02, 24576 bytes
                   Driver: C:\Windows\system32\oemdspif.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:16, 69632 bytes
                   Driver: C:\Windows\system32\igfxrara.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 229376 bytes
                   Driver: C:\Windows\system32\igfxrchs.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 155648 bytes
                   Driver: C:\Windows\system32\igfxrcht.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 155648 bytes
                   Driver: C:\Windows\system32\igfxrdan.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 258048 bytes
                   Driver: C:\Windows\system32\igfxrdeu.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
                   Driver: C:\Windows\system32\igfxrenu.lrc, 7.14.0010.1591 (English), 10/28/2008 02:04:12, 249856 bytes
                   Driver: C:\Windows\system32\igfxresp.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
                   Driver: C:\Windows\system32\igfxrfin.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 258048 bytes
                   Driver: C:\Windows\system32\igfxrfra.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
                   Driver: C:\Windows\system32\igfxrheb.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 225280 bytes
                   Driver: C:\Windows\system32\igfxrita.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 278528 bytes
                   Driver: C:\Windows\system32\igfxrjpn.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 184320 bytes
                   Driver: C:\Windows\system32\igfxrkor.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 180224 bytes
                   Driver: C:\Windows\system32\igfxrnld.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 274432 bytes
                   Driver: C:\Windows\system32\igfxrnor.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 253952 bytes
                   Driver: C:\Windows\system32\igfxrplk.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 262144 bytes
                   Driver: C:\Windows\system32\igfxrptb.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 266240 bytes
                   Driver: C:\Windows\system32\igfxrptg.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 270336 bytes
                   Driver: C:\Windows\system32\igfxrrus.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 266240 bytes
                   Driver: C:\Windows\system32\igfxrsky.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 258048 bytes
                   Driver: C:\Windows\system32\igfxrslv.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 253952 bytes
                   Driver: C:\Windows\system32\igfxrsve.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 258048 bytes
                   Driver: C:\Windows\system32\igfxrtha.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 237568 bytes
                   Driver: C:\Windows\system32\igfxrcsy.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 258048 bytes
                   Driver: C:\Windows\system32\igfxrell.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 286720 bytes
                   Driver: C:\Windows\system32\igfxrhun.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 262144 bytes
                   Driver: C:\Windows\system32\igfxrtrk.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 253952 bytes
                   Driver: C:\Windows\system32\ig4icd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:14:34, 3895296 bytes
                   Driver: C:\Windows\system32\ig4dev32.dll, 7.15.0010.1591 (English), 10/28/2008 02:14:44, 2359296 bytes
                   Driver: C:\Windows\system32\igd10umd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:21:36, 2256896 bytes
                   Driver: C:\Windows\system32\igdumdx32.dll, 7.15.0010.1591 (English), 10/28/2008 02:25:44, 536576 bytes
                   Driver: C:\Windows\system32\igfxCoIn_v1591.dll, 10/28/2008 02:35:26, 147456 bytes
                     Name: Mobile Intel(R) 4 Series Chipset Processor to DRAM Controller - 2A40
                Device ID: PCI\VEN_8086&DEV_2A40&SUBSYS_306D103C&REV_07\3&E89B380&0&00
                   Driver: n/a
                     Name: Intel(R) ICH9 Family PCI Express Root Port 6 - 294A
                Device ID: PCI\VEN_8086&DEV_294A&SUBSYS_306D103C&REV_03\3&E89B380&0&E5
                   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:55, 149480 bytes
                     Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
                Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_306D103C&REV_03\3&E89B380&0&E3
                     Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
                Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_306D103C&REV_03\3&E89B380&0&E2
                     Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
                Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_306D103C&REV_03\3&E89B380&0&E0
                     Name: High Definition Audio Controller
                Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_306D103C&REV_03\3&E89B380&0&D8
                   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/10/2009 22:42:42, 561152 bytes
                     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
                Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_306D103C&REV_03\3&E89B380&0&D7
                   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18465 (English), 5/5/2011 07:54:07, 39936 bytes
                   Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18875 (English), 6/28/2013 20:07:01, 226304 bytes
                   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18875 (English), 6/28/2013 20:07:15, 197632 bytes
                   Driver: C:\Windows\system32\hccoin.dll, 6.00.6002.18465 (English), 5/5/2011 10:01:28, 8704 bytes
                   Driver: C:\Windows\system32\hcrstco.dll, 6.00.6002.18465 (English), 5/5/2011 10:01:28, 15872 bytes
                     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
                Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_306D103C&REV_03\3&E89B380&0&EF
                     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
                Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_306D103C&REV_03\3&E89B380&0&D1
                   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6002.18465 (English), 5/5/2011 07:54:07, 23552 bytes
                     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
                Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_306D103C&REV_03\3&E89B380&0&D0
                     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
                Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_306D103C&REV_03\3&E89B380&0&EA
                     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
                Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_306D103C&REV_03\3&E89B380&0&E9
                     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
                Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_306D103C&REV_03\3&E89B380&0&E8
                     Name: Intel(R) ICH9 Family SMBus Controller - 2930
                Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_306D103C&REV_03\3&E89B380&0&FB
                   Driver: n/a
                     Name: Intel(R) ICH9M/M-E Family 4 Port SATA AHCI Controller - 2929
                Device ID: PCI\VEN_8086&DEV_2929&SUBSYS_306D103C&REV_03\3&E89B380&0&FA
                   Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:28, 27112 bytes
                   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:52, 43496 bytes
                   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:26, 19944 bytes
                   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:42, 109032 bytes
                     Name: Intel(R) ICH9M LPC Interface Controller - 2919
                Device ID: PCI\VEN_8086&DEV_2919&SUBSYS_306D103C&REV_03\3&E89B380&0&F8
                   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/20/2008 20:23:01, 16440 bytes
                     Name: Intel(R) 82801 PCI Bridge - 2448
                Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_306D103C&REV_93\3&E89B380&0&F0
                     Name: Realtek RTL8102E/8103E Family PCI-E Fast Ethernet NIC (NDIS 6.0)
                Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_306E103C&REV_02\4&2ABD10AA&0&00E3
                   Driver: C:\Windows\system32\DRIVERS\Rtlh86.sys, 6.213.1110.2008 (English), 11/10/2008 14:26:00, 135680 bytes
                   Driver: C:\Windows\system32\RtNicProp32.dll, 1.01.0716.2008 (English), 7/21/2008 07:08:40, 9728 bytes
                DirectShow Filters
                DirectShow Filters:
                WMAudio Decoder DMO,0x00800800,1,1,,
                SM AAC Decoder DMO,0x00200000,1,1,,
                WMAPro over S/PDIF DMO,0x00600800,1,1,,
                WMSpeech Decoder DMO,0x00600800,1,1,,
                MP3 Decoder DMO,0x00600800,1,1,,
                Mpeg4s Decoder DMO,0x00800001,1,1,,
                WMV Screen decoder DMO,0x00600800,1,1,,
                WMVideo Decoder DMO,0x00800001,1,1,,
                SM H264 Decoder DMO,0x00200000,1,1,,
                Mpeg43 Decoder DMO,0x00800001,1,1,,
                Mpeg4 Decoder DMO,0x00800001,1,1,,
                MainConcept (Muvee) MPEG Demultiplexer,0x00400001,1,2,muveempgdmx.ax,7.03.0000.36147
                CyberLink Audio Decoder (HP),0x00200000,1,1,CLAud.ax,6.03.0000.1029
                CyberLink Audio Decoder (QP),0x00200900,1,1,CLAud.ax,6.03.0000.1029
                PCM Video/SP Decoder,0x00200000,2,3,PCMRVSD.ax,6.00.0000.3922
                MSDVD Audio Wizard (HP),0x00200910,1,1,CLAudWizard.ax,1.00.0000.1730
                Full Screen Renderer,0x00200000,1,0,,6.06.6002.18725
                CyberLink Volume Meter,0x00200000,1,0,HPVolumeMeter.ax,1.00.0000.0001
                CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
                CyberLink TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1401
                CyberLink DVD Navigator (HP),0x00200000,0,3,CLNavX.ax,7.00.0000.4710
                Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
                WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
                WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
                Cyberlink Track Filter,0x00200000,1,1,YCTrack.ax,1.01.0000.0222
                PCM Audio Decoder,0x00200000,1,1,PCMRAud.ax,6.00.0000.4104
                CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
                CyberLink Line21 Decoder Filter (HP),0x00200000,0,2,CLLine21.ax,4.00.0000.9027
                PCM Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
                DV Muxer,0x00400000,0,0,,6.06.6001.18000
                CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRmpegvanalyzer.ax,2.00.0000.2620
                PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
                CyberLink File Map Source,0x00200000,0,1,PCMRFMSrc.ax,1.00.0000.0810
                CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
                Color Space Converter,0x00400001,1,1,,6.06.6002.18725
                CyberLink XDS Codec,0x00200000,1,0,PCMRxdscodec.ax,1.00.0000.0322
                CyberLink Demultiplexer,0x00200000,1,0,PCMRdemuxer.ax,1.00.0000.7104
                WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
                WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
                Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
                AVI Splitter,0x00600000,1,1,,6.06.6002.18725
                MainConcept (Muvee) MP4 Multiplexer,0x00200000,1,1,muveemp4mux.ax,7.07.0000.36147
                VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18725
                CyberLink Video Effect (HP),0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
                ReTimeStamp Filter,0x00200000,1,1,ReTimeStamp.ax,1.00.0000.0001
                CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
                CyberLink TimeStretch Filter (HP),0x00200000,1,1,clauts.ax,1.00.0000.5423
                Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
                QuickPlay Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
                CyberLink Audio Noise Reduction,0x00200000,1,1,PCMRAuNRWrapper.ax,1.00.0000.1318
                CL_EVRWindow,0x00200000,0,0,PCMREvr.dll,1.00.0000.2315
                AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                Cyberlink SubTitle Importor (HP),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
                WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
                9x8Resize,0x00200000,1,1,WMM2FILT.dll,
                MainConcept MPEG Splitter,0x001fffff,1,2,mcspmpeg.ax,1.01.4178.0000
                MainConcept MPEG Audio Decoder,0x00600000,1,1,mcdsmpeg.ax,1.01.4178.0000
                MainConcept MPEG Video Decoder,0x00600000,1,1,mcdsmpeg.ax,1.01.4178.0000
                MainConcept MPEG Encoder,0x001fffff,2,1,mcesmpeg.ax,1.02.4178.0000
                MainConcept MPEG Video Encoder,0x001fffff,1,1,mcevmpeg.ax,1.02.4178.0000
                MainConcept MPEG Audio Encoder,0x001fffff,1,1,mceampeg.ax,1.02.4178.0000
                MainConcept MPEG Multiplexer,0x001fffff,1,1,mcmuxmpeg.ax,1.30.4178.0000
                CyberLink DVB Subtitle Decoder,0x00200000,1,1,PCMRDvbSub.ax,1.00.0000.4413
                StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
                WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
                Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
                MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18725
                CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
                MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18725
                CyberLink Pipe Switch,0x00200000,1,1,PCMRPipSwch.ax,1.00.0000.3215
                SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18725
                P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
                MainConcept (Muvee) Stream Parser,0x00400001,1,2,muveempgdmx.ax,7.03.0000.36147
                CyberLink XDS Codec,0x00200000,1,0,PCMRxdscodec.ax,1.00.0000.1016
                VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
                CyberLink AVI Audio Time Regulator,0x00200000,1,1,PCMRAVI_AudTR.ax,1.00.0001.0213
                CyberLink Demultiplexer,0x00200000,1,0,PCMRdemuxer.ax,1.00.0000.6327
                CyberLink File Map Sink,0x00200000,1,0,PCMRFMSnk.ax,1.00.0000.0810
                MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
                WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
                CyberLink Audio Effect,0x00200000,1,1,PCMRAudFx.ax,6.00.0000.0805
                MainConcept (Muvee Consumer) AVC/H.264 Video Decoder,0x00400001,1,2,muveestdavcvd.ax,7.05.0000.36147
                YC_EVRWindow,0x00200000,0,0,YCEvr.dll,1.00.0000.2531
                MediaWriter Filter,0x00200000,1,0,mediawriter.ax,6.00.0058.7993
                Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
                CL_EVRWindow,0x00200000,0,0,CLEvr.dll,1.00.0000.1717
                CyberLink Push-Mode CLStream (cURL),0x00200000,0,1,CLStream(MultiLib).ax,1.01.0000.4421
                Stretch Video,0x00200000,1,1,WMM2FILT.dll,
                Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18725
                CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,8.02.0000.0630
                CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
                QuickPlay MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.5229
                P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
                MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18725
                CyberLink Audio Decoder (HP),0x00200000,1,1,CLAud.ax,6.01.0008.5319
                CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRttxdec.ax,2.05.0000.5730
                DV Splitter,0x00600000,1,2,,6.06.6001.18000
                CyberLink PTS Regulator,0x00200000,1,1,PCMPTSReg.ax,1.00.0000.1209
                Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18725
                CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
                Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.3504
                MainConcept (Muvee) AAC Decoder,0x00400001,1,1,muveedaac.ax,7.06.0000.36147
                Cyberlink SubTitle(HP),0x00200000,1,1,CLSubTitle.ax,1.00.0000.4716
                PCM SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,1.00.0000.2504
                muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,6.00.0056.7596
                muvee Source Filter,0x00200000,0,1,muveesource.ax,6.00.0058.7993
                CyberLink Video Effect (HP),0x00200000,1,1,CLVidFx.ax,1.00.0000.2024
                PCM Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.3512
                CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
                CyberLink EPG Decoder,0x00200000,1,1,PCMREpgDec.ax,1.00.0000.2917
                Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
                HP VTK MPEG-1 Encoder,0x00200000,3,3,hpqvtk01.dll,120.00.0110.0011
                Frame Eater,0x00200000,1,1,WMM2FILT.dll,
                CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.2307
                CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
                CyberLink Video/SP Decoder (HP),0x00600000,2,3,CLVSD.ax,8.02.0000.0630
                QuickPlay Demultiplexer,0x00200000,1,0,CLDemuxer.ax,1.00.0000.5609
                Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
                CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
                ACM Wrapper,0x00600000,1,1,,6.06.6002.18725
                Cyberlink Streamming Filter,0x00200000,0,1,CLStream.ax,1.01.0000.4624
                CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRttxdec.ax,2.05.0000.4428
                Video Renderer,0x00800001,1,0,,6.06.6002.18725
                QuickPlay SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,1.00.0000.2504
                MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
                Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
                Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
                CyberLink AudioCD Filter (HP),0x00600000,0,1,CLAudioCD.AX,5.00.0000.0912
                CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.4924
                Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
                CyberLink Push-Mode CLStream,0x00200000,0,1,CLStream(PushMode).ax,1.01.0000.4705
                Video Port Manager,0x00600000,2,1,,6.06.6002.18725
                Video Renderer,0x00400000,1,0,,6.06.6002.18725
                WAV Dest,0x00200000,0,0,wavdest.ax,
                QuickTime Encoder,0x00200000,1,0,quicktimesink.ax,6.00.0058.7993
                CyberLink Audio Effect (HP),0x00200000,1,1,claudfx.ax,6.00.0000.5103
                Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
                CyberLink Line21 Decoder Filter,0x00200000,0,2,PCMRLine21.ax,4.01.0000.0820
                CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
                Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
                Proxy Source,0x00200000,0,1,WMM2FILT.dll,
                CyberLink MPEG Splitter(Scramble),0x00200000,1,2,CLSplter.ax,3.02.0000.4119
                HP VTK Rotate Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
                WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
                QuickPlay Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
                CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
                CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,3.00.0000.2215
                MES Video Source,0x00200000,0,1,mesvideosource.ax,6.00.0058.7993
                VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
                PCM MPEG-2 Splitter,0x00200000,1,2,PCMRM2Splter.ax,2.02.0000.4328
                CyberLink TimeStretch Filter,0x00200000,1,1,PCMRAuts.ax,1.00.0000.2108
                WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
                File writer,0x00200000,1,0,,6.06.6001.18000
                Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
                CyberLink SBE Source Filter,0x00200000,0,0,PCMRsbesrc.ax,2.00.0000.2620
                CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
                QuickPlay MPEG Video Encoder 2,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
                PCM Audio Encoder,0x00200000,2,0,PCMRaudenc.ax,2.01.0000.2031
                Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
                PCM Dump Filter,0x00200000,1,0,PCMRdump.ax,3.00.0000.8231
                CyberLink Line21 Decoder Filter (QP),0x00200000,0,2,CLLine21.ax,4.00.0000.7602
                CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
                CyberLink TL MPEG Splitter,0x00200000,1,2,YCTLMSplter.ax,3.02.0000.2219
                Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.3504
                Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.2718
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.02.0000.3829
                CyberLink SBE Filter,0x00200000,0,0,PCMRsbe.ax,2.00.0000.3207
                CyberLink DVD Navigator (HP),0x00200000,0,3,CLNavX.ax,7.00.0000.4704
                muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,6.00.0056.7596
                CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
                DVD Navigator,0x00200000,0,3,,6.06.6002.18533
                WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
                Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
                CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRmpegvanalyzer.ax,2.00.0000.3207
                mvAudioScope,0x00200000,1,0,mvaudioscope.ax,6.00.0058.7993
                Bouncing Ball,0x00200000,0,1,,
                PCM Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
                MainConcept (Muvee2) Layer II Audio Decoder,0x00400001,1,1,muvee2l2ad.ax,7.04.0000.34713
                CyberLink DVB Subtitle Decoder,0x00200000,1,1,PCMRDvbSub.ax,1.00.0000.3927
                CyberLink MP3 Wrapper-PCM,0x00200000,1,1,PCMRmp3wrap.ax,1.00.0000.0000
                MainConcept (Muvee) MPEG Multiplexer-Plus,0x00200000,1,1,muveempeg2mux.ax,7.06.0000.36147
                AVI Draw,0x00600064,9,1,,6.06.6002.18725
                MainConcept (Muvee) MPEG Multiplexer,0x00200000,1,1,muveemuxmpeg.ax,7.03.0000.36147
                muvee Deinterlace Filter,0x00200000,1,1,mvdeinterlace.ax,6.00.0058.7993
                Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
                CyberLink Demultiplexer(Scramble),0x00200000,1,0,CLDemuxer.ax,1.00.0000.6807
                WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
                MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
                Record Queue,0x00200000,1,1,WMM2FILT.dll,
                QuickPlay Video/SP Decoder,0x00200000,2,3,PCMRVSD80.ax,8.02.0000.1106
                DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
                PCM MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.01.0000.1217
                CyberLink Audio Decoder,0x00200000,1,1,CLAud61.ax,6.01.0008.5503
                CyberLink SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.2802
                MainConcept (Muvee) MPEG-2 Video Decoder,0x00400001,2,2,muveem2vd.ax,7.05.0000.36147
                CyberLink WMV/WMA Demultiplexer,0x00200000,1,2,CLWMFDemux.ax,1.00.0000.4323
                CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1513
                CyberLink SBE Source Filter,0x00200000,0,0,PCMRsbesrc.ax,2.00.0000.3207
                HP VTK Frame Grabber Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
                SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.19118
                Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.19118
                CyberLink WebCamera NULL Render,0x00200000,0,0,YCWEBCAMERARENDER.ax,2.00.3519.2318
                WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
                QuickPlay MPEG-2 Splitter,0x00200000,1,2,PCMRM2Splter.ax,2.02.0000.2114
                QuickPlay Audio Decoder,0x00200000,1,1,PCMRAudX.ax,6.03.0000.1029
                MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
                Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
                CyberLink Video Regulator,0x00200000,1,1,YCRgl.ax,3.00.0000.1228
                WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
                IDM Filter,0x00200000,1,1,idmf.ax,1.00.0000.3909
                CyberLink TimeStretch Filter(HomeNetwork),0x00200000,1,1,clauts.ax,1.00.0000.5423
                Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.2718
                CyberLink Video/SP Decoder (QP),0x00200000,2,3,CLVSD.ax,8.02.0000.0619
                StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
                muvee FileDump Filter,0x00200000,1,0,mvfiledump.ax,6.00.0058.7993
                PCM RTP Source Filter,0x00200000,0,1,PCMRRTPSrc.ax,1.00.0000.1826
                CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.2026
                CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
                Smart Tee,0x00200000,1,2,,6.06.6001.18000
                Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
                CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
                AVI Decompressor,0x00600000,1,1,,6.06.6002.18725
                CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
                WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
                CyberLink Video/SP Decoder (HP),0x00200000,2,3,CLVSD.ax,8.02.0000.1117
                CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.2024
                NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
                CyberLink Demultiplexer (HP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.5405
                CyberLink Audio Noise Reduction,0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1611
                CyberLink Audio Effect (HP),0x00200000,1,1,claudfx.ax,6.00.0000.1223
                AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18725
                WMT Volume,0x00200000,1,1,WMM2FILT.dll,
                Wave Parser,0x00400000,1,1,,6.06.6002.18725
                MIDI Parser,0x00400000,1,1,,6.06.6002.18725
                Multi-file Parser,0x00400000,1,1,,6.06.6002.18725
                File stream renderer,0x00400000,1,1,,6.06.6002.18725
                CyberLink SBE Filter,0x00200000,0,0,PCMRsbe.ax,2.00.0000.2620
                MES Audio Source,0x00200000,0,1,mesaudiosource.ax,6.00.0058.7993
                CyberLink WMV Dumper (YouCam),0x00200000,2,0,YCWMVDump.ax,1.00.0000.2303
                HP VTK Resize Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
                CyberLink Audio Spectrum Analyzer (HP),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
                CyberLink Audio Resampler,0x00200000,1,1,CLAuRsmpl.ax,2.00.0000.0411
                WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
                QuickTime Source Filter,0x00200000,0,1,quicktimesource.dll,6.00.0058.7993
                Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
                AVI Mux,0x00200000,1,0,,6.06.6001.18000
                CyberLink DVD Navigator (QP3),0x00200000,0,3,CLNavX.ax,7.00.0000.4710
                CyberLink Audio Spectrum Analyzer (HomeNetwork),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
                muvee WAV Encoder,0x00200000,0,0,mvwavencoder.ax,9.00.0000.0000
                CyberLink Scene Detect Filter 2,0x00200000,1,1,CLScnDt2.dll,1.01.0000.3202
                Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18725
                File Source (Async.),0x00400000,0,1,,6.06.6002.18725
                File Source (URL),0x00400000,0,1,,6.06.6002.18725
                CyberLink Line21 Decoder Filter (HP),0x00200000,0,2,CLLine21.ax,4.00.0001.7527
                Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
                P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
                QuickPlay MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.01.0000.1129
                AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
                AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
                SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
                P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
                CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.6529
                Cyberlink File Reader (Async.),0x00400000,0,1,CLAsyReader.ax,1.00.0000.1319
                CyberLink Audio Decoder,0x00200000,1,1,CLAud.ax,6.01.0008.4721
                QuickPlay Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.3512
                QuickPlay Audio Encoder,0x00200000,2,0,PCMRaudenc.ax,2.01.0000.2031
                KsProperty Interface Null,0x00200000,1,1,PCMRKsPropertyNull.ax,9.00.0000.0000
                QuickPlay Dump Filter,0x00200000,1,0,PCMRdump.ax,3.00.0000.8618
                Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
                WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
                CyberLink DTVCC Decoder Filter,0x00200000,0,2,PCMRDTVCC.ax,1.00.0000.2112
                Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
                CyberLink MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.4811
                Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
                MainConcept (Muvee) MP4 Demultiplexer,0x00400001,1,2,muveemp4demux.ax,7.07.0000.36147
                CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3423
                BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
                CyberLink WMV Dumper(HP),0x00200000,2,0,PCMWMVDump.ax,1.00.0000.1526
                CyberLink SAC Video Decoder,0x00200000,2,3,CLVSD.ax,8.03.0000.1017
                MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18725
                CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
                WDM Streaming Tee/Splitter Devices:
                Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
                Video Compressors:
                WMVideo8 Encoder DMO,0x00600800,1,1,,
                WMVideo9 Encoder DMO,0x00600800,1,1,,
                MSScreen 9 encoder DMO,0x00600800,1,1,,
                DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
                MJPEG Compressor,0x00200000,0,0,,6.06.6002.18725
                Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
                Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
                Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
                Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
                Audio Compressors:
                WM Speech Encoder DMO,0x00600800,1,1,,
                WMAudio Encoder DMO,0x00600800,1,1,,
                IMA ADPCM,0x00200000,1,1,,6.06.6002.18725
                Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18725
                GSM 6.10,0x00200000,1,1,,6.06.6002.18725
                CCITT A-Law,0x00200000,1,1,,6.06.6002.18725
                CCITT u-Law,0x00200000,1,1,,6.06.6002.18725
                MPEG Layer-3,0x00200000,1,1,,6.06.6002.18725
                Audio Capture Sources:
                Integrated Microphone Array (ID,0x00200000,0,0,,6.06.6001.18000
                External Mic (IDT High Definiti,0x00200000,0,0,,6.06.6001.18000
                Stereo Mix (IDT High Definition,0x00200000,0,0,,6.06.6001.18000
                Midi Renderers:
                Default MidiOut Device,0x00800000,1,0,,6.06.6002.18725
                Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18725
                WDM Streaming Capture Devices:
                ,0x00000000,0,0,,
                MicIn,0x00200000,1,1,,6.00.6001.18000
                MuxedIn1,0x00200000,1,1,,6.00.6001.18000
                ,0x00000000,0,0,,
                USB Video Device,0x00200000,1,2,,6.00.6001.18000
                WDM Streaming Rendering Devices:
                HpOut,0x00200000,1,1,,6.00.6001.18000
                ,0x00000000,0,0,,
                ,0x00000000,0,0,,
                Speaker,0x00200000,1,1,,6.00.6001.18000
                BDA Network Providers:
                Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
                Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
                Video Capture Sources:
                HP web camera filter,0x00200000,0,1,YCWebCameraSource.ax,2.00.3519.2318
                Multi-Instance Capable VBI Codecs:
                BDA Transport Information Renderers:
                BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
                MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
                BDA CP/CA Filters:
                Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
                Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
                WDM Streaming Communication Transforms:
                Audio Renderers:
                Speakers and Headphones (IDT Hi,0x00200000,1,0,,6.06.6002.18725
                CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,6.00.0000.2108
                CyberLink Audio Renderer (HP),0x00200000,1,0,CLADR.ax,6.00.0000.5222
                Default DirectSound Device,0x00800000,1,0,,6.06.6002.18725
                Default WaveOut Device,0x00200000,1,0,,6.06.6002.18725
                DirectSound: Independent Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,,6.06.6002.18725
                DirectSound: Speakers and Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,,6.06.6002.18725
                Independent Headphones (IDT Hig,0x00200000,1,0,,6.06.6002.18725
                • 5. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
                  j_woody Level 1
                  I'm now getting a crash on the "Non-HTML5 video", and the flash logo no longer shows on the page:
                  • 6. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
                    It looks like you're about four years behind on drivers for your graphics hardware.
                    Here's a link to the current installer for 32-bit Vista:
                    https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22163&lang=eng&ProdId=2991
                    I'm not sure that this will fix the issue since you're seeing it both with hardware acceleration enabled and disabled, though.
                    In Firefox, if you type about:crashes in the address bar, you'll get a list of crashes.
                    Click the link and it will submit the report to Mozilla and open a new page.  Copy and paste the address from the new window into a reply.  If you have more than one from the last couple days, a few would be helpful.
                    In Firefox, if you choose Menu (hamburger icon) > Help (?) > Restart with Add-Ons Disabled, does this crash persist?
                    Thanks!
                    • 7. Re: Adobe Flash Player 15.0 r0 Has Stopped Working
                      j_woody Level 1
                      Thanks very much for your help  .... you've given me a number of things to check, and I'll continue to work on this over the next week or so.  In the meantime, if I need to play any videos, I just use Google Chrome.
                      Thanks Again  ... you've been very helpful!
