1 Reply Latest reply on Nov 10, 2014 12:19 PM by try67
    Import/export to an Access DB
    MatLac Level 3
      Considering the following Workflow:
      File created under Acrobat and distributed manually on local server.
      Form filled using Reader and submitted as complete file dynamically via JS to local email;
      Reviewed using Reader (might upgrade to Acrobat if needed) correct the form if needed or send it back to user;
      Content manually copied to an acces file as a way to store the data.
      How can I automate the part where values entered in the form are copied to the acces file.  Is there a way to import/export the values or is the only solution to use adobe's own  "distribution/data collection" system?
      Would submitting the PDF as well as an XML/FDF/CSV file a good solution?
