5 Replies Latest reply on Nov 10, 2014 12:46 PM by Cellanurse86
    Converting words to numbers
    Cellanurse86
      Hi all!
      I've seen multiple questions/answers about converting numeric values to words in Java, but I have the reverse issue.
      I've created a performance management appraisal (dropdown box) with the following ratings:
      Exceeds
      Achieves
      Below
      Unsatisfactory
      However, in order to execute some calculations, I need to assign numeric values to each
      Exceeds (4); Achieves; (3) Below; (2); Unsatisfactory (1).
      I would REALLY appreciate it if someone could help me with the code for this.  My intent is create a separate field called "r_value" to display the number (I'll make this invisible later) and use for other calculations.
      Also, I'm assuming this should be written as a Validation script, correct?
      Thanks SO much!
      Cheers!
