1. Re: Adobe Flash problem!?
Ned Murphy Nov 10, 2014 12:22 PM (in response to SpaceMermaid)You appear to have triggered the Object Drawing mode.
Press the J key on your keyboard and see if it returns to what you want. That might be what you did to trigger it to start, otherwise you would have to have selected the control directly.
To get a better idea of the animal you let loose, with the brush tool selected move down and hover over the drawing controls below the drawing tools and find the one that has a popup label of "Object Drawing (J)"... it is the one with a circle surrounded by a rectangle - kinda like what you get when it is on. If it is/was selected then you would be in the Object Drawing mode.
2. Re: Adobe Flash problem!?
SpaceMermaid Nov 10, 2014 12:56 PM (in response to Ned Murphy)Yep!
Thanks dude!
I must have pressed 'j' instead of 'k' (for fill tool)
As idiotic as i feel right now - thankyou anyway!
3. Re: Adobe Flash problem!?
Ned Murphy Nov 10, 2014 4:49 PM (in response to SpaceMermaid)You're welcome
