9 Replies Latest reply on Nov 9, 2018 6:19 PM by lulua71561693
    I Can't open books on my Kobo e-reader
    Matou75
      Hello,
      I want to open e-books that i have downloaded on my e-reader. But when I try to open it it says:
      This file can not be opened.
      This document is protected by Adobe Digital Rights Management (DRM) and is currently not accessible with you Adobe ID. Sign in with the autorized Adobe ID and try again.
      I have authorized the pc and the -ereader with the same email adress, but on the site that i have dowloaded books from, I use two other adresses. Can anyone help me?
        • 1. Re: I Can't open books on my Kobo e-reader
          GurvA Level 1
          I am also having this issue and have tried everything to correct it (uninstall, reinstall, different version) but I still cant open the books on my Kobo.  The Adobe support line has been completely useless. Does anyone know how to correct this?
          • 2. Re: I Can't open books on my Kobo e-reader
            brr&squeak
            I have been having the same issue with library ebooks and they have been helping me. Delete adobe digital edition 4.0 and download 3.0. Mine is working now, after 2 weeks of trying.
            • 3. Re: I Can't open books on my Kobo e-reader
              GurvA Level 1
              Hi I was getting the same message on my Kobo touch when I tried to open library books (This document is protected by Adobe Digital Rights Management (DRM) and is not currently authorized for use with your Adobe ID.  Please sign-in with the authorized Adobe ID and try again).  After reading a few posts on this issue, I did the following:
              - make sure you have Adobe 3.0
              - deauthorize the computer using the instructions from their site (OverDrive | How to deauthorize Adobe Digital Edition...)
              - get a book from the library book
              - when prompted, open using ADE (or download- I just said open instead of download)
              - when you try to open the book in ADE, it'll ask you to authorize computer
              - I put in my authorization (the same as my Kobo) then transferred the book to my Kobo.
              - I was then able to open my library book in my Kobo!
              • 4. Re: I Can't open books on my Kobo e-reader
                peppa
                Thank you so much for this brilliant tip about deauthorizing. It works!!
                • 5. Re: I Can't open books on my Kobo e-reader
                  BonBon19
                  Yes, I am having the same problem.  My eReader (KoBo) has worked fine for several years but just this week has begun to not allow me to open books I have downloaded from my library using ADE.
                  Help!
                  • 6. Re: I Can't open books on my Kobo e-reader
                    Matou75 Level 1
                    Hello, I have solved the problem. I deauthorized the pc and e-reader and deleated ADE form the computer. After that I installed ADE 3.0 and authorized pc and reader. And now I can finallye read some books!. So try that and let me know!
                    • 7. Re: I Can't open books on my Kobo e-reader
                      drjardine
                      Thank you GurvA for the steps to get it working.
                      Macbook Air - Yosemite OSX
                      Uninstalled ADE 4.0 (completely uninstall - move to trash, Finder > Go and type /~Library and go to Application Support folder > Adobe Digital Editions and move to trash the dat files. Then empty Trash.
                      I followed as you said and it worked for the first book. The second book, ADE crashed on me when I tried to open once downloaded. So I navigated to File > Add to library and found the ascm file in my downloads (am on a MAC) and added to the library. This worked and was able to add the 2nd book to my kobo (kobo Aura)
                      • 8. Re: I Can't open books on my Kobo e-reader
                        BonBon19 Level 1
                        Yes, the key is to deauthorize on the pc before deleting the program -
                        eventually I installed ADE 4.0 and now it works!  Thanks
                        • 9. Re: I Can't open books on my Kobo e-reader
                          lulua71561693
                          I randomly have this same problem. My latest fix was the easiest! I deleted the book from my reader and from Digital Editions (it was still signed out from the library-just deleted from all devices) I opened Adobe Digital Editions on my computer and went into preferences - and unchecked the box "Library Sync option: automatically download your synced books to this device"[which would be my COMPUTER].  (I did actually have my KOBO plugged into my computer as I did this, but when the KOBO asked if I wanted to connect to the computer I chose CANCEL). I then was going to go back and re download the book and add to Adobe Digital Editions BUT- THE BOOK JUST SHOWED UP on my KOBO and I was able to open it.  Also, somewhere in the whole process I went to HOME on my KOBO and signed into my home library - as I noticed on the HOME page a button that said "learn how to borrow ebooks from your public library" and it led me through the steps for signing in. I hope this helps. I also HAD TO sign up for an adobe account just so I could reply on this forum! But I know I have done the laborious process of de-authorizing before and it was really annoying- so I hope this is an easier work around for someone!
