This content has been marked as final.
Show 11 replies
1. Possible to determine image dimensions on cffile upload?
jdeline Mar 23, 2007 9:05 AM (in response to Gregory@ETR)Page 6 of http://www.w3.org/Graphics/JPEG/jfif3.pdf describes the location of the Xdensity and Ydensity fields (2 bytes each) for a JPEG. http://www.martinreddy.net/gfx/2d/GIF87a.txt will tell you similar information about the GIF file format.
If that's too much to digest, get yourself a good custom tag, or wait for native functionality in ColdFusion 8. Google coldFusion "custom tag" "image size" -
2. Re: Possible to determine image dimensions on cffile upload?
ghouser Mar 23, 2007 9:26 AM (in response to Gregory@ETR)Yes, I use a script that will determine the dimensions so I can put the heigth and width into database fields for use laster. I will attach the code I use for you.
3. Re: Possible to determine image dimensions on cffile upload?
Abinidi Mar 24, 2007 2:13 AM (in response to ghouser)or...
<cfset image_name ="C:\pathtofile\imagefile.jpg">
<cfscript>
imgFile = createObject("java","javax.swing.ImageIcon").init("#image_name#");
imgFile.getImage();
w = imgFile.getIconWidth();
h = imgFile.getIconHeight();
</cfscript>
<cfoutput>width="#w#" height="#h#</cfoutput>
Adjust code accordingly to what you are doing. -
4. Re: Possible to determine image dimensions on cffile upload?
Newsgroup_User Mar 26, 2007 8:00 AM (in response to ghouser)Abinidi wrote:
> <cfscript>
> imgFile.getImage();
> </cfscript>
this is way cool, man!
do you know if there is a way to check the dimensions of an uploaded
flash (swf) movie ?
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
http://www.sabai-dee.com -
5. Re: Possible to determine image dimensions on cffile upload?
cf_dev2 Mar 26, 2007 6:53 PM (in response to Newsgroup_User)>do you know if there is a way to check the dimensions of an uploaded
>flash (swf) movie ?
I have never used it but you might check out FlashInspector.CFC at
http://www.doughughes.net/index.cfm?event=viewEntry&entryId=166 -
7. Re: Possible to determine image dimensions on cffile upload?
Newsgroup_User Apr 1, 2007 10:09 AM (in response to ghouser)Abinidi wrote:
> or...
> <cfscript>
> imgFile.getImage();
> </cfscript>
i am trying to use the above code to check for dimensions of uploaded
image and delete the image (through cffile action=delete) if its
dimensions are different from required. the checking part works fine,
but i am unable to delete the image!
CF trows an error:
ColdFusion could not delete the file "[full path to file]\[filename]"
for an unknown reason.
the path is correct, the file is there, and i can delete it manually
without a problem, but not with cffile action=delete...
any ideas? does that have something to do with the instantiated java
object? how do i de-instantiate it?
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
8. Re: Possible to determine image dimensions on cffile upload?
Newsgroup_User Apr 2, 2007 6:00 PM (in response to ghouser)well, i have come up with a work-around, but would still like to learn
how (if possible) to release a java object invoked with createObject()...
in case anyone is interested, the work-around i implemented is:
add uploaded files of wrong dimensions to a list, after succefful upload
of correct file pass the list to another page which silently loops
through it and deletes the files from server and returns user to
original calling page...
Azadi Saryev
Sabai-dee.com
9. Re: Possible to determine image dimensions on cffile upload?
cf_dev2 Apr 27, 2007 1:08 PM (in response to Newsgroup_User)Azadi,
I ran a few tests and cffile delete worked. So I'm not sure what the problem is. I looked at the cfc and it refers to two java classes.
java.io.ByteArrayInputStream
java.util.zip.InflaterInputStream
Both classes have a close() method, though ByteArrayInputStream.close() doesn't do anything. For grins .. you might try adding a function to the FlashInspector.cfc that calls the close() method on the java objects. Then call that function just before attempting to deleting the file. I don't know that it will help but its worth a shot.
10. Re: Possible to determine image dimensions on cffile upload?
Newsgroup_User Apr 27, 2007 11:18 PM (in response to Newsgroup_User)thanks for your input, cf_dev2!
i was actually having the problem with getting jpeg dimensions using
Abinidi's code that uses javax.swing.ImageIcon class, not the
FlashInspector.cfc...
the FlashInspector works like a charm... it's the created java object
that would not release and let me delete the jpeg image if its
dimensions are wrong...
i have since switched to using imagecfc from opensourcecf - a lot more
code, but all packed into a cfc, and lets you resize/crop the image to
correct dimensions instead of just telling the user "sorry, your image
is wrong size, please resize and re-upload"...
but thank for your time looking into this, and your url for the
FlashInspector.cfc was a true lifesaver!
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
11. Re: Possible to determine image dimensions on cffile upload?
cf_dev2 Apr 28, 2007 12:07 AM (in response to Newsgroup_User)> i was actually having the problem with getting jpeg dimensions
Azadi,
Well that's what I get for trying to read before I've had my morning coffee ;-)
Now that I think about it I remember having a similar problem. Either with java.swing.ImageIcon or java.awt.Image or both. But it sounds like imagecfc has solved your problem and it does have some great features.
Until next time then!
