2 Replies Latest reply on Nov 10, 2014 4:24 PM by lkmlkmkm
    I need a Adobe Edge simple machine tutorial!
    lkmlkmkm
      Hello, I'm looking for a tutorial that will help me make one of the fallowing machinesin adobe edge; 1. A lever is a stiff bar that rests on a support called a fulcrum which lifts or moves loads. There are three classes of levers. 2. A pulley is a simple machine that uses grooved wheels and a rope to raise, lower or move a load. 3. A wedge is an object with at least one slanting side ending in a sharp edge, which cuts material apart. 4. A wheel with a rod, called an axle, through its center lifts or moves loads. 5. An inclined plane is a slanting surface connecting a lower level to a higher level. 6. A screw is an inclined plane wrapped around a pole which holds things together or lifts materials.
      I hope someone can help!
